Hi -
I am going to update a 3 way system that I built back in 1980. It has an 8" woofer replaced in 2005 due to the foam surround on the original cracking up. Woofer is Dayton RS225S-8. Box is ported for Qts=0.38 driver with fs=27Hz, and is cut over at 1Khz. Not sure of the brand for the mid - It has and fs of about 400Hz, is Ferrofluidic cooled, rolls off starting 5.5Khz. All I recall is that it cost ~ $60 at the time (most expensive part of the system) is stamped "made in Belgium" on it and has no name anywhere else. I originally built the system with a Moto Piezo horn (gasp!) hooked up with an Lpad and a series cap. I would like to update it with something that would have flatter freq response and better dispersion for <~$25 per tweet and was thinking of either:
Vifa 19mm D19TD-05 for about $17 or the Beston Ribbon Tweet RT001A for about $25. I would X over between 4-5Khz
Any advice??
Any advice??
