Its not speakers really but most people seem to read here and you guys know about tools!
I need a pair of pointy-nosed wire clippers. I have some normal wire clippers but I need to get in to a tighter gap. Anyone know where I can get some with a nice pointy cutting end?
Here are my current ones
Channellock
The only brand I use anymore...
Just buy them new, it will save you grief in the long run.
http://www.channellock.com/acb/stores/1/728_-_7_5_inch_Diagonal_Cutter_P31C16.cfm
http://www.channellock.com/acb/stores/1/748_-_8_inch_End_Cutter_Long_R_P62C16.cfm
http://www.channellock.com/acb/stores/1/437_-_7_inch_Cutting_Plier_-_B_P98C9.cfm
http://www.channellock.com/acb/stores/1/Cutting_Pliers_C9.cfm
http://www.channellock.com/acb/stores/1/Long_Reach_Pliers_C16.cfm
http://www.channellock.com/acb/stores/1/LITTLE_CHAMP__C12.cfm
And the new ones!
They look burned because I heated them up and cooled them very fast after the grinding to harden the cutters.
Hey Tenson,
I hope you got them hot enough to temper before you quenched. That would have meant removing the plastic handles. If not the heating will have distempered the metal making them weaker. Did you not have a can of water beside you while grinding?
That being said, they should be strong enough for copper still.
- Need a tool!
