this is my amp:
the Power Folllower
with IRFP140 , 2Amperes and 30 volt B+ , CHOCKE INPUT, in air - 30 mH - PSU mica coupling caps.😎
I wajnt know if your expert opinion, I can succesfully replace the current generator with a inductance .😕
Since the amp is only for > 300 Hz , I suppose the inductance will be more small, less THD on the highs, and more little and cheap( instead fullrange operation).
Am I right?
And it would be double the watts , am I right?
thanks for the help🙂
paolo
the Power Folllower
Am I right?
paolo
post your schematic proposal
however - with choke instead of CCS , you need to decrease PSU voltage , to keep dissipation in normal range
reason - choke will drop voltage just for it's Rdc x Iq
Won't a choke then limit the output voltage swing and therefore reduce power available?
Choke will develope it's own 1/2 output swing with changing current! The benifit of a choke load 😀
oh, thanks
but upper ,in blue there is the link to my AMP( ANDREA CIUFFOLI'S SCHEMATYCS)
THANKS
PAOLO
THANKS
PAOLO
Generally speaking, I think the answer is yes. It will of coarse not be the same Amp 😀
Might I suggest something already tried? Have you heard of Pathos?
The flopping around of the PSU connection and bias could still be applied to this output stage.
PATHOS italian amp?
Hi, is it this the schematcis of the italioan Pathos TT 30 watt ??😱
very thanks!!!
paolo🙂
BUT th emy question remein still open...
What about BUZ mosfety?? MAGNATEC iuf I wel l remember.....
cheers
paolo
NEM speakers Research and Developments
very thanks!!!
paolo🙂
cheers
paolo
Hey ,
THOSE BIG - ENORMOUS , AND EXPANSIVE INDUCTANCE OF 5-6 aMPERS IN OUTPOUT , ARE THEY INDISPENSABLE???😕
THANKS🙂
THANKS🙂
I don't know about indispensable? You are the one that suggested an inductor in place of a current source. Maybe there is a language problem or I no comprendere?
The real importantance is in the construction and materials of that "Iron". You can search the forum. I have seen some threads regarding these amps but the question is, what core material and how is that iron made? A standard Hammond Mfg. E core will work but likely introduce distortions since they are mostly made for power supplies (50-60Hz) and not high frequencies? they will also physically ring under load. It is possible to make a huge inductor with air core from a 1000' roll of magnet wire. I suspect it would largely avoid the distortion and saturation problems 😀
excuse ME , YOU ARE ABSOLUTELY RIGHT. iT IS THE DIFFERENT DISPOSITION THAT MADE ME TINKING AT DIFFERENT DEVICE, I'M SORRY TO DISTURB WITH MY VERY POOR ELECTRONICS KNOWLEDGE..
btw :THANKS FOR THE INTERESTING SCHEMAYTIC , BUT FOR MY POWER FOLLOWER 2007 AUDIODESIGNGUIDE.COM , WITH ONLY 2 AMPERES AND UPPER 300 hZ 6 dB /OCT HIGH PASS , WICH TYPE /SIZE/COST AND PERFORMANCE I NEED???😕
VERY THANKS FOR PATIENT AND HELP ME...
IF I CAN RE-CHANGE FAVOUR WITH A NEW X-OVER FOR YOUR SPEAKERS , I'LL DO IT FREE 😉
CHEERS
inertial, please refer to the rules item (see rule #16) regarding use of capitals.
http://www.diyaudio.com/forums/site-announcements/167561-diyaudio-rules.html
It's fine guy's. I don't hear well anyway. I ussually have to ask for someone to repeat things as a routine... Isn't that ironic? someone like me, on an Audio forum??
excuse me , sir
I have to ask excuse but i haven't do not realized rule N 16..
I'm very sorry of this. :-(
cheers
cheers
- need a suggestion for my power follower
