Hi first post, I need to find an equivalent or replacement for a 2N6728.
thanks for your help.
data sheet
http://www.datasheetcatalog.org/datasheet/zetexsemiconductors/2n6728.pdf
data sheet
bc640 should do.
Thanks J! but do you think an A56 would make a good replacement?
data sheet
http://www.fairchildsemi.com/ds/PZ/PZTA56.pdf
i don't have any bc640 but i do have a ton of A56's....
thanks
2SB957...58
BD518
BD526
All rated at 60V 2A
thanks for the info RS!
The MPSA56 won't do. The current rating is way below the 2N6728.
The actual circuit its used in needs to be studied to see what might be suitable. Without doing that, you have to select devices that are at least as well specified or better than the original.
- Need a replacement for a 2N6728
