I've been looking around for an board, something like the CDB4272 or a circuit board that I can have made at JLCPCB or others, that would have two channels of balanced analog input with AESBU output, ideally, or I2S/SPDIF.
I have a lot of old recording equipment like DAT and ADAT that I like to use, but their ADCs are 30yrs old. I have a couple outboard ADCs but they are over 10yrs old too. I had thought about using the CDB4272 but that eval board is like $450 and I could probably draw the schematic and have my own made. I'm very good with micros of all types, have tons (literally) of test equipment so making a debugging isn't a big deal, just wondering if anyone already went this route and has a board posted someplace? Output needs to have 16bit at 48khz minimum and then selectable higher bit and sample rates. I also need the word clock output.
Jerry
Jerry
No idea about ADCs that're less than 10 years old but DIT4192 is a nice SPDIF (IEC-60958) chip if that helps, standalone, no microcontroller and the channel status bits are user controllable, if I understand correctly.
https://www.aliexpress.com/item/4001345914017.html
The following evaluation board from TI includes all what you want:
Schematics, BOM and gerber files are available along with user guide for free:
User Guide:
https://www.mouser.com/datasheet/2/405/sbau124-123933.pdf
Gerber files:
https://www.ti.com/lit/zip/slac510
- High-performance A/D with balanced inputs,
- I2S, AES , DSD outputs.
User Guide:
Gerber files:
