Need 600Watts Or Greater
hi!
i need power amplifiers having 500watts RMS or greater..
500watts RMS or greater @4ohms(1channel)
all bipolar transistors from small stage to output
and the speakers to be drive are 2pcs crown 18" ranges 500-1000W
so 4speakers all for 2channels
What will be its Vrails for this specs?
anyone have this design that matches this?
Thanks!!!
How about some UCD700's?
At >500W RMS /channel you're going to be pumping out an awful lot of heat with a class AB design. Definitely a good reason to go down the class D route. I'm not saying it's not doable, it most definitely is possible, but personally I wouldn't like having that much heat to put up with.
