hey all. im already thinking ahead to my next project.
i want to make a new monoblock for my bass transducers. they cannot, (read, CANNOT) handle more than 25 watts. a mono channel is fine. so, if i could make a 25-watt version of the aleph3, that would do, OR a 25-watt zen amp?
the thing is, i already have more than enough parts for a single aleph3. i would just need case, power supply. but i have all resistors, etc.
any ideas? is it possible to get the aleph3 down to only 25-watts? and if so, would it run cooler?
25 WATT MOSFET with good data.
😉 25 WATT MOSFET of very good quality
Try this on, cowanrg
Will save you a lot of money.
Allowing you to build 2-4 with same money.
And if you modify it,
start a thread about it.
I would like to know the details!
If your mind is set to want a Zen-amplifier
Call it "Cowan-Tzen One" and ingrave that on the front
and it will "sound" more Tzenish.
you people think i care about money 🙂
im looking for best, not that which is "very good". i will clearify, the amp must produce either 50W power at 8ohms. its going to power 2 transducers are 25W each. (sorry, forgot to mention that)
and how will that amp save me money? aside from heastinks (and of course power supply, which is pretty standard across the board), i already have all the parts needed for the aleph3.
i guess ill rephrase, which would be the best 50-watt monoblock? im really dumb about electronics, i cant modify to save my life. i just copy what others have done. im just here to make stuff that i could normally not afford. sorry nelson, the real alephs are out of my price range 🙂
After many questions, reading reviews, getting opinions, I settled for the Aleph30. Alot of folks consider it to be the best in it's class, even better then the Krell KAV 300i .
i would, but can it do 50W instead of 60W? if so, decision is made 🙂
Nelson Pass said:So build one, already.
cowanrg said:i would, but can it do 50W instead of 60W? if so, decision is made 🙂
It can do anything you ask for.😉
Cowanrg,cowanrg said:i would, but can it do 50W instead of 60W?
The Aleph 3 (which you have the parts for) calls for 2 plus and 2 minus output devices per channel. This might be a little light for 50W into 8ohms. You may want to use 3plus and 3 minus output devices per channel. Then you would have an Aleph 5.😉
Rodd Yamashita
well, if i wire the transducers in parallel, i get 4 ohms from them, therefore, that would be 60w from an aleph3? could i run it lower to get it around 50? wait, i think the answer is yes 🙂
Limiting power? In the words of Mickey Thompson, "too much power is almost enough". The sin would be for your bass drivers to run dry. ie, It's not what you got, it's how you use it.
Quite right,
You're more likely to damage your speakers with an underpowered amplifier being overused than you are with an overpowered amplifier being underused.
Similarly, this is why many people would like a 180mph Ferrari, even though they will never take it beyond 120mph.....Hmmmm, that was a pleasant dream. 😀 😀
Paul
Paul
The Alephs were very conservatively designed, and practically
none have failed after 11 years.
You can push an Aleph 3 to 50 watts, and maybe one out of
10 will fail inside of 5 years, I reckon.
I decided on the Aleph 30 as it seems to be a good sounding amp and it does not produce too much heat. If I like it enough I will build an Alpeh X next. It can also be built quite compact. The pic shown all boards for a two channel amp except discrete bridges. This is my "proof-of-concept" amp and if it works out OK I will build a proper chassis...
/UrSv
/UrSv
Very nice UrSv,
One question, where do you buy these IRF240 in europe, here in Holland they are expensive ;(.
Unfortunately it seems they are quite expensive everywhere and the cheapest source so far is direct from IR.
For decent prices on IR (EUR 2.31 each at qty 10+) parts try:
http://www.schuro.de/
The others have them but for good prices you need larger quantities:
http://www.farnell.com/
http://www.rscomponents.com/
For other than IR parts this is good at EUR 1.40 each:
http://www.reichelt.de
/UrSv
/UrSv
30Watt to 50Watt
How would I do this on Aleph30?
Will it be by changing value of R16 and R17 or must you increase rail voltage also?
Nelson Pass said:You can push an Aleph 3 to 50 watts, and maybe one out of
- need 25W amp, aleph 3 or zen?
