NECX and NESX Single-Ended to Balanced Converters
A direct consequence to the successful revision of the XCEN 2018 is the reverse of that.
Namely the NECX single-ended to balanced converter.
https://www.diyaudio.com/forums/ana...d-single-converter-revisited.html#post5596866
But just as in the case of CEN/SEN IV, one can build a version of that with N & P cannel JFETs.
But one can also build one using N JFETs only, hence the addition NESX converter.
The first idea went all the way back to 2011, so it is another unfinished business to tidy up :
https://www.diyaudio.com/forums/solid-state/200325-fet-based-phase-splitter-8.html#post2814583
Surprising, both versions have very similar performance.
At 1kHz 2Vrms differential output, NECX has -86dB H2 and -109dB H3.
NESX, on the other hand, has -88dB H2 and -106dB H3.
Without global NFB, without saying. :)
You can read about the details in the article.
Patrick
  • NECX Description Public 181028.pdf
