NE5532 is a popular opamp
Back in the mid-1980s, there was a company in Tucson by the name of Analog Systems. I was never clear on how many chips they designed but they did bin the NE5534, NE5532, and either the TL-07X or maybe the LF35X series.
The MA-332 was a NE5534 with internal compensation (a single NE5532) that met the following specs:
+-20V slew rate, 5nV noise, +-22V DC power
The MA-362 was a drop in for any NE5534, gain of 5 minimum, +-12 to +-17V/s slew rate, Noise measured at 10 Hz and 1 kHz and put on the spec sheet - 2.5 to 4 nv, max DC power +-24V.
They sold a lot of them to the Pro Audio folks in Los Angeles and of course to a few home audio folks that got wind of them.
Analog or digital? I know of several microcontrollers that are one-engineer designs. Digital VLSI is basically programming. But in one sense its got to be true as developing processes is a whole separate strand of design and no IC can be made without a process.
With the exception of a few test chips at university, all ICs I have ever worked on (all analogue or mixed-signal) were designed by teams. I never worked on op-amps though, rather on receivers and transceivers.
My colleagues on the digital side normally also work in teams. Sometimes digital back-end design (their equivalent of layout) is done by one person, but then there are one or more other people doing the digital front end.
Reactions: The Lord Flashheart
