NDK NZ2520SDA oscillators group buy
Some updates:
NZ2520SDA Group buy:
Lorien - 10 pairs
modmix - 2 pairs
nounouchet - 1 pair
stonedowner - 1 pair
Richard S. - 1 pair
carsten.witt - 2 pairs (WaveIO + BluWave)
Emi90 - 1 pair
chris719 - 2 pairs
Fujak - 1 pair
Extreme_Boky - 2 pairs (WaveIO x 2)
m.massimo - 1 pair (WaveIO)
Hires - 2 pairs
Tods - 2 pairs
audiopassion - 5 pairs
inMotion - 1 pair
chansiukwing - 2 pairs
Patrick B. - 1 pair (BluWave)
kvl - 2pairs
mm2 - 1 pair (BluWave)
JohnnyInBris - 2 x 22.5792 MHz
crowlie - 6 x 22.5792 MHz and 3 x 24.5760 MHz
jptz - 2 pairs
Dave B. - 3 pairs
koala887- 2 pairs
M_Balou - 1 pair
merlin el mago - 3 pairs
miksi - 1 pair
randytsuch - 1 pair
nielsek - 1 pair
xaled - 1 pair
Ben Mah - 1 pair
bwaslo - 2 x 24.5760 MHz
Joseph K - 5 pairs
pistollero - 2 pairs
EasternBlock - 3 pairs
TNT - 2 pairs
Micael C. - 1 pair
I sent PMs to all of you but in case someone was missed please let me know!
L
1. Lorien - 10 pairs
2. modmix - 2 pairs
3. nounouchet - 1 pair
4. stonedowner - 1 pair
5. Richard S. - 1 pair
6. carsten.witt - 2 pairs (WaveIO + BluWave)
7. Emi90 - 1 pair
8. chris719 - 2 pairs
9. Fujak - 1 pair
10. Extreme_Boky - 2 pairs (WaveIO x 2)
11. m.massimo - 1 pair (WaveIO)
12. Hires - 2 pairs
13. Tods - 2 pairs
14. audiopassion - 5 pairs
15. inMotion - 1 pair
16. chansiukwing - 2 pairs
17. Patrick B. - 1 pair (BluWave)
18. kvl - 2pairs
19. mm2 - 1 pair (BluWave)
20. JohnnyInBris - 2 x 22.5792 MHz
21. crowlie - 6 x 22.5792 MHz and 3 x 24.5760 MHz
22. jptz - 2 pairs
23. Dave B. - 3 pairs
24. koala887- 2 pairs
25. M_Balou - 1 pair
26. merlin el mago - 3 pairs
27. miksi - 1 pair
28. randytsuch - 1 pair
29. nielsek - 1 pair
30. xaled - 1 pair
31. Ben Mah - 1 pair
32. bwaslo - 2 x 24.5760 MHz
33. Joseph K - 5 pairs
34. pistollero - 2 pairs
35. EasternBlock - 3 pairs
36. TNT - 2 pairs
37. Micael C. - 1 pair
38. taggart2 - 1 pair
2. modmix - 2 pairs
7. Emi90 - 1 pair
9. Fujak - 1 pair
12. Hires - 2 pairs
13. Tods - 2 pairs
18. kvl - 2pairs
22. jptz - 2 pairs
27. miksi - 1 pair
30. xaled - 1 pair
36. TNT - 2 pairs
39. Jose H. - 1 pair
Edit: thank you Felipe, a nice weekend to you too!
2. modmix - 2 pairs
7. Emi90 - 1 pair
9. Fujak - 1 pair
12. Hires - 2 pairs
13. Tods - 2 pairs
18. kvl - 2pairs
22. jptz - 2 pairs
27. miksi - 1 pair
30. xaled - 1 pair
36. TNT - 2 pairs
40. boborah - 1 pair
41. mmerrill99 - 3 pairs
@ mmerrill99: Paypal invoice will come in a couple of minutes!
Thank you,
L
Yesterday evening I managed to ship out all the NDK pairs so the list is updated as follows:
2. modmix - 2 pairs
3. nounouchet - 1 pair (Shipped)
4. stonedowner - 1 pair (Shipped)
7. Emi90 - 1 pair (Shipped)
8. chris719 - 2 pairs (Shipped)
9. Fujak - 1 pair (Shipped)
12. Hires - 2 pairs (Shipped)
13. Tods - 2 pairs (Shipped)
16. chansiukwing - 2 pairs (Shipped)
18. kvl - 2pairs (Shipped)
20. JohnnyInBris - 2 x 22.5792 MHz (Shipped)
21. crowlie - 6 x 22.5792 MHz and 3 x 24.5760 MHz (Shipped)
22. jptz - 2 pairs (Shipped)
24. koala887- 2 pairs (Shipped)
25. M_Balou - 1 pair (Shipped)
26. merlin el mago - 3 pairs (Shipped)
27. miksi - 1 pair (Shipped)
28. randytsuch - 1 pair (Shipped)
29. nielsek - 1 pair (Shipped)
30. xaled - 1 pair (Shipped)
31. Ben Mah - 1 pair (Shipped)
32. bwaslo - 2 x 24.5760 MHz (Shipped)
33. Joseph K - 5 pairs (Shipped)
34. pistollero - 2 pairs (Shipped)
35. EasternBlock - 2 pairs
36. TNT - 2 pairs (Shipped)
41. mmerrill99 - 3 pairs (Shipped)
I'm sorry it took so long for some of you (Fujak) but I wanted to ship out all parts together - so no 'discrimination' involved 😱.
I cut the ordered number of oscillators directly from the received NDK's tapes on reels to avoid touching their pads (thus staying away from ESD troubles for as much as possible). Each type of oscillators was packed in a separate small plastic bag marked with respective part's frequency. I know those parts are really small for most of us so I thought I might help out by marking them properly. Both bags were glued to a piece of carton to add some mechanical strength.
The rest of envelope does contain (too many) bubble wraps to be on the safe side.
Sadly, I have no equipment nor time or experience to measure phase noise for each of those parts and select the best of them from my two batches. Because of that, all the oscillators were given as the next one available from tapes. I'm sorry that I cannot do more on this but those phase noise measurement gears are insanely expensive for my budget! 😱
In addition, I never test the parts I sent to you but taking into account my past experience with NDK I don't think it was required! So far I never had any troubles with NDK oscillators... and I used a lot of them!
Well, I had some issues but it was solely my mistake (parts were burned with hot air gun or damaged by using improper PSU)!
Speaking of mistakes, I cannot be held responsible if any of you will damage those parts! It's up to you how those NDKs will be soldered, powered, kept away from ESD discharges, moisture or very high/low temp usage! Please check their datasheet prior using them!
And, since I've learned my lesson, make sure you're confident prior soldering your parts! Some of you will only have on pair at disposal!
Make sure you'll see the lasered dot which marks the pin 1 on the package!
If it happens to own other boards with such parts mounted on them which is of no/limited use, I recommend you to try your soldering/desoldering skills on those ones first!
Last night I sent PMs (to provided personal email accounts) with tracking numbers and links to all of you who have your NDKs marked as shipped! If you didn't receive any news please PM me!
That's all for now! Just remember to announce on this thread if you'll get your parts and if part's numbers are matching your order!
In the end I want to quote Johan as he beautifully said, "may they spread nice and warm music in peoples hearts and minds". 🙂
Kind regards,
L
