I know this must have been asked many times before but I'll ask anyway.
I have an active loudspeaker system build around a DEQX crossover/preamp a pair of w-baffle woofers driven with UCD700 amps, a pair of Phy-Hp semi-fullrange drivers on open baffle and air motion transformer on top.
For years I have been driving the mids and highs with tube amps (ECL82 pp on mids and 300B SET on tweeters) Thsi sounded very good. Problem is that I had to swap tubes almost every year. I listen to music all day and when I'm not at home my family listens to music all day. It's on for about 4 to 16 hours a day. So I wanted to get rid of the tubes.
After trying a lot of ss amps I settled down on a Hiraga le class A 20W on the tweeters and an Audiosector lm3875 gainclone on the mids. As always I end up using the best sounding amp on the tweeters. I'm pretty allergic to bad highs, spoils all the fun of listening to music.
The ss combo does not sound as good as the tubes but it comes close. The mids are a bit too dry (the typical ss dryness I guess) and could use some more body in the lower midrange and highs are sometimes a bit shrill at louder volumes. At lower volumes everything is just fine. Resolution is pretty good as is soundstaging. even if it is not as good as the tubes I can at least listen to it as long as with the tubes, fatigue is very low.
For some time now I've been reading up in the Naksa 70 amps. The six million dollar question is offcoarse: Would the Naksa's sound closer or maybe even better then the tube amps in my system.
I have been reading every review I could find on them but in general I think most owner/reviewer are using a completely othe loudspeaker system then I do. The Phy-hp are like 50's radio loudspeakers on the wrong amp. On the right amp they are marvelous. They do not like typical ss amps, and the don't like amps with very a high dampening factor. They sound at best with an amp that has a combination of speed and a bit of bold character.
Too bad I can't hear the Naksa by myself, I'm realy interested but 4 channels of Naksa from down under is affordable when I like them but very expensive if I don't.
