Nakamichi cdc-3a laser?
It's a Pioneer PWY1009, used in almost every Pioneer 6-disc changer model made from around 1987-90 or later(PD-M400-PD-M910, more or less). They don't go bad very often, even now, other than the common failure of the glue that holds the lens into the focus actuator(which is simply a matter of rescuing the lens from where ever it's rattling around in the unit & carefully gluing it back in place).
Hi Stephensank or other fellow ...
As the glue Pioneer use is water based and in high humidity conditions it fall apart , what kind of glue did you recomend?
Thanks in advance.
