Najda DSP board setup file - please help
Hi, I'm new here but figured I'd jump right in with a problem that is bugging me.
I have in my possession a Nadja DSP Preamp with a v1.3 board. This unit fixes all the time alignment issues with my system but I no longer have a copy of the .nsf Nadja Setup File. Is there a way to read the setup file from the board? Or is there some other way to derive the parameters from the board?
Thanks in advance for you help.
Unfortunately not, you can only save the setup file locally on the computer or sync it with the board and then it gets loaded as a preset. You cannot do it the other way around and save a preset on the board back into a setup file, as far as I can see at least. There must be some hack or way to do it though? The data must be saved somewhere on the board, which means it should be retrievable with the right code/software?
Are there any Najda nerds about or does anyone still have contact with the guys that owned or worked at WAF Audio?
