traderbam said:
Good. Then how would you rate Naim against other brands in this regard?
That is a bit of a vague question. What exactly are you alluding to ??
Naim is only one example of a compromised design. There are many others. This is all you need to know and it is pointless trying to rank something like that.
x-pro, you have seen the point I am getting at.
I guess you could make a Naim clone that was actually "better" than a Naim but it would still not be a Naim.
Arthur, I have a 32 preamp with a SNAPS power supply I use for phono. For cd the line stage is not as good as a passive attenuator.
sp
sp
stoolpigeon said:I guess you could make a Naim clone that was actually "better" than a Naim but it would still not be a Naim.
Suppose you go and buy a NAP250. You audition both channels and find they sound the same. You take all the parts out of one channel and set them aside. You then replace them with the same make and part no. components which you have bought yourself (and therefore are chosen at random from batches). You flow-solder the board to keep the joints in good working order, like Naim do.
Now you audition the two channels again. Do they still sound the same?
stoolpigeon said:x-pro, you have seen the point I am getting at.
sp
Mate you need to seriously think about upgrading. I mean buying something completely different 😉
Suppose you go and buy a NAP250. You audition both channels and find they sound the same. You take all the parts out of one channel and set them aside. You then replace them with the same make and part no. components which you have bought yourself (and therefore are chosen at random from batches). You flow-solder the board to keep the joints in good working order, like Naim do. Now you audition the two channels again. Do they still sound the same?
why would anyone do that?
Roar Malmin said:Can anybody post schematic on an ORIGINAL NAP250 amp?
Roar
Is this it ??
22kOhm
Hi Hugh,
It was Ben Duncan, bashing D. Self's balanced input stage and current mirror. (EW+WW, April 1995, pp. 308-309)
Edmond.
Originally posted by AKSA (post #82)
Edmond,
Could you enlighten us who this 'guru' might be?
It occurs to me that tubes do this kind of thing, which is naughty of them (cough)......
Hi Hugh,
Edmond.
Thanks. Looks peculiar, I seem to remember that John mentioned earlier that one of the virtues were a lack of protection? BTW, nice scheme for tailoring the distribution of distortion artifacts, the 22K in the LTP.
I can see where DS got one of his ideas now. In this particular constellation, with almost nonexistent heatsink, it is a must.
Roar
Roar
Hi Edmond,
so Ben Duncan brought the LTP out of balance?? What a pity, as I like his book and it does not appear to use such tricks.
All the best, Hannes
The very same Ben Duncan also called DSs amps "piddling". Nice word, piddling. Feels very small.
Roar
Roar
Roar Malmin said:Thanks. Looks peculiar, I seem to remember that John mentioned earlier that one of the virtues were a lack of protection? BTW, nice scheme for tailoring the distribution of distortion artifacts, the 22K in the LTP.
Roar
Why tailor the distortion ?? Why not get rid of the distortion all together and know that your amplifier is not adding stuff to the original signal in any way 😉 Isn't that what it's all about ??
snoopy said:
Is this it ??
1. I think the NAP250 had a regulated PS.
2. bc239 can't handle 40V.
ron
Snoopy, I fully agree with you on that topic, but this is an old amp, and it is VERY simple. It is almost impossible to make one with fewer parts, so you are forced to make sacrifices in the distortion department. The loading on the VAS is far too high, and factor after factor can be mentioned, but JV deliberately choose to make it like this, so your comments doesn`t really apply.
I made power amplifiers from approx -83. I used mainly 2SA1227 and 2SC2987, lovely NEC ring emitters. Of course, these amps were not QC, but PP. During that period I used almost five thousand pairs. JV, if he wanted, could also have converted his amps to PP, but he elected not to do so, so he must have been satisfied with the fruit of his looms, so to speak.
BTW, do you remember the ad with this chap standing rubbing his chin, looking at a NAIM amp on a crushed floor. "Sorry I didn`t catch your NAIM". Just fantastic.
Roar
Roar
It's close, but the circuit I have traced from an 1980 example varies in 10 or so part values and specs.Originally posted by snoopy
Is this it ??
The general geometry of the schematic is correct though.
PHEONIX said:
Hello Hugh
Do you think it is possible to design a good sounding amplifier that has low distortion.
Arthur
Bellow 0.5% distortion is inaudible,matters little,whats important is the subjective evaluation that is based on other things
Hope this helps Sir Arthur....😀
martin clark said:It's close, but the circuit I have traced from an 1980 example varies in 10 or so part values and specs.
There were many incarnations of the same model. Apparently they kept the same models going for years and decades !!
Arthur,
Yes, I believe it's important, particularly for large orchestral rendition.
Edmond,
Many thanks, Ben always was kinda Zen...... I wonder why he didn't keep his mouth shut, that was tactless.
Pretty impressive thread, doncha know!!
Hugh
Edmond,
Hugh
AKSA said:Arthur,
So are you saying the lower the better ??
- Naim (split from Blowtorch)
