Hello, Just bought a Naim 32-5 pre-amp off Ebay. When I opened the box could hear rattling so looked into case and discovered 3 of the little daughter boards were loose. Put them back where I think they go but not sure. It's a very early model 0079. If anyone can help me with a jpeg of the board how it should be that would be great. I can post some images also. It seems to be layed out as seperate channels one per board so I've put the 3 boards back together. Its the phono amp boards that have come off. Thanks
Usually there are two phono boards and there is only one way they fit on the pin sockets as long as all the pins are in the sockets you should be ok.
Hello,
Thanks for that. Have you got any more details of the 32-5 ? jpegs of circuit board etc. Regards
Naim 72
Hello,
I'm building a Naim 72.5 clone and I'm very happy if somebody can mail picture of the motherboard (in front of and behind ) without the others cards (324, 326, 726 ..)
Best regard
Hello,
Best regard
- NAIM 32-5 circuit board problem
