I just got this amp in and it works fine in stereo mode but when its bridge theres a buzzing sound coming out at low volume. When I turn it up it kind of goes away. when the volume is at 0 you can here it the music very low and distorted. will using a balance or unbalance signal effect it.🙁
there should be no difference balanced or unbalanced.
you are changing the speaker load connections when using bridge mode?
