NAD C320BEE - Bad capacitors?
I read through your post and yes,we still need to stick positive rail.I do notice that the ohm reading is considerable low, which meaning there is something pulling the current.Since the +/-18V is supplying the preamp module too, can you remove all of them and measure the voltage again?And of course, those caps around the +18V rail might be the culprit too, but we can work on the module first.
The clarify, which module? Or disengage the whole circuit by desoldering the first component?
