NAD 7240 PE Resistor Blown
Hi all, I recently was given my dad's old 7240PE which he said just stopped working one day. Taking a look inside I saw all of the 4a and 5a fuses had blown. For the rest of this post I will be referencing the service manual found here: https://www.audioservicemanuals.com/n/nad/nad-60-7600/nad-7240/15238-nad-7240-pe-service-manual
My first step was taking out the driver transistors (Q427,428,429,430) and putting new fuses back in. Turning it on, R495 burst in a flame of glory. It's worth noting that the fuses did not blow, but I'm still a little concerned to do any further damage. Because of this I plan on proceeding with caution... and with the help of the internet.
I've poked around with my DMM and noticed that C427's points on the board are shorted even after I desoldered it (the cap itself was fine). Any ideas where to go next?
Hi jommint,
Welcome to the forum!
I suspect this will be a challenging repair. I've attached a pdf of a service manual that seems to have better print quality than the one from your link. You should probably confirm it's appropriate for your amp's SN. It came from: https://www.manualslib.com/manual/1724963/Nad-3240.html#manual I hope other members may have repair experience with this amp; I'll be working solely from the schematic.
Note that page 5 of the attachment recommends using a light bulb current limiter for testing after repair. Do you have a scope? Perhaps current-limited bench supplies?
So, were Q427,428,429,430 absent from the board during your first test? (I'm not saying this would be a bad idea.)
From the schematic, I would think you would see at least R457's 10 Ohm resistance, probably more. Would you double check? (and try exchanging meter leads for polarity check.)
Good luck!
Always you have a failed device in your workbench use a limited current supply. This way you prevent future damage. A light bulb of the filament type (no led nor fluorescent) in series to the live cord of the line. You may do it with a dedicated outlet or wire a lamp holder with a couple of cucodrile clips, thus remove the DUT's fuse and use it in place of the said fuse.
The lamp must be about 1 to 5 times the power of the DUT, not much more. Under normal conditions you should see a flash in the lamp immediatly after power on, because of capacitor charge. After it, lamp must be completely dark or a soft red in the filament.
