NAD 7020E radio part does not work well
does not research and save.
It won't autostore channels, and unusually you have to press enter first then the reqd preset to store the current freq, not the other way round which might sound more usual.
If it forgets memory in less than ~2 weeks (specs) then you need to double check supply voltage to P42 of Q911 (AKA IC911) is 5.0V
The 4700uF (C914 - not huge for a backup cap) on pin 42 is the main suppy and memory backup supply for memory, so check that if 5V is ok or just replace.
PM channel is weak
it does not research
Does it actually receive any FM stations ?
