I have one 3130 that is canibalized
made my repairs and replaced what ever needed but i have asymetrical cliping
Pos side starts to clip too early like 20 W
any hints ?
Blody schematic have no voltage reference VAS is supplied with about 36V after the resistor 35.4 Dont know if this is enough
Any ideas ?
thanks
any hints ?
Any ideas ?
thanks
If R435/436 are high in value, the current produced will not be suffucient to drive the positive going signal above a lower limit to the negative side.
Do not use "equivalent" transistors, their hfe will be wrong and could also cause this issue.
