Omron G2RL-2A4 24VDC is fitting and working 100%, no need to cut the extra legs but if this one isnt in stock G2RL-24 works aswell but you have to cut 2 legs. Digikey and Mouser have them in stock. To be honest many relays 24vdc from Finder, Panasonic and schrack will work too..
And servicetip is also if you need to replace above mentioned resistors you should also resolder all A970 and C2240 transistors in the poweramp (near the 47k ohm resistors..) Look after the hotspots... and all other transistors aswell that sits on heatsink or near one. Also caps near heatsinks will be dead especially the YEC branded ones.. if you have nichicons they're probably alive still.
