My NAD 304 has a problem with the right hand channel. This stays mute for about 10 minutes after switch-on, then bursts into life and works fine until switched off. There is no intermittent on and off, no break up or crackling. The pre-amp section is OK -headphones work fine. The speakers work ok when swapped over. I can live with this fault, but would prefer not to. Anyone got any ideas?
Cheers
Neil
Cheers
Neil
