NAD 3020 transistors position.
Here's a handy internal shot, transistor fans!
If you align the transistors in the same direction as the photos, you don't need a lecture, schematic or anything further. There are only 2 options for each transistor and the markings on each transistor, as well as the position of the holes in the PCB show whether each transistor is oriented either up or down (as shown in pics).
It's nearly impossible to get that wrong, unless of course, you can't see the pics. or the schematics. Try here: NAD 3020A Schematic These from Plant 10 are actually f...you want to hear the original product by DIY.
I would start with getting the power amplifier stage into working condition (or verifying that it is working OK).
Before doing the basic forenzics (DC voltages, sine signal on scope) I would replace the tantalum capacitors in the signal path:
C601...C604.
After that I would feed signal to "NORMAL IN" i.e. input of the power stage from another device (preamplifier, computer sound card etc) that I know to be in working condition.
Once you get the power amplifier stage working OK then you ca start with the preamplifier section.
They only fit in one way !
The two pins underneath are offset if you look.
Note insulators only fit right one way too.
I bought in a 2n3055/mj2955 Maplin amp to repair.
I replaced 2n3055/mj2955 with modern versions with same number and the amp oscillated.
I can only guess new transistors had more gain or a wider bandwidth.
I had to increase the VAS capacitor to stop the oscillation.
