I recently purchased a NAD 2600 that appeared to be in beautiful condition - it was never worked on and cosmetically looked 10/10. It was clear the amp was rarely used and babied. However, once I plugged it in and powered it on, the protection light came on immediately and stayed on. This happens with or without any speakers/inputs connected.
What I have done: I took off the cover and checked all the fuses - each appears to be intact.
I looked at all the components and none seem to be burnt out - none of the electrolytic capacitors are bulging and no resistors are burnt.
What I have looked into: I have read up on the protection relays and do not this this is the issue because protection stays on. From other forum posts I have read, it seems like checking voltages is the next step.
My questions: Is there a good guide for how to safely power on an amp and check voltages hot? I have HV electronics experience but nothing on amps. Are their components that are known to go bad with age on this amp that I can check? I have a bench top multimeter and scope on hand. Has anyone had this issue and knows where to start?
Any insight or references would be greatly appreciated.
Thank you,
Josh 🙂
Thank you,
Josh 🙂
Why haven't you checked the condition of the output devices ?
Look for a short circuit for a start , that doesn't require powering the amplifier up.
The protection is related to overload (current ) so the output would be the first logical step --if okay then check the overload detector and two relays .
A pretty good schematic is available on hi-fi engine , just login.
google search " nad 2600 service manual "
from vintageshifi.com, no need to sign up.
just click the "nad 2600 service manual" it will automatically download.
read the manual , get familiar with the manual.
locate every part from the manual with the broad.
transistors C B E identification. also diodes, capacitors,
use your multimeter, diode mode, continuity, DC, AC volts....
page 15/21
Power supply
check all the voltages according to the schematic.
if all voltages normal--
page 11/21
check L302, R channel output, should be 0v or a few mV DC to ground, ( + or - )
check L301, L channel output, should be 0v or a few mV DC to ground, ( + or - )
if there were voltage, the protection relay won't activate and stay on protect mode.
check all the voltages according to the schematic to locate the fault.
Power supply
page 11/21
The right channel output is 94V. The left channel output was 0.7V and is rising. I'm afraid it is one of the output transistors for both channels. How do I check them? I do not have a transistor tester.
if the right channel is outputting 94v, then the output devices Q332 and/or Q330 are likely blown- You need also to check Q324/Q328 and Q322/Q326 as well.
the 94v- is that +ve or -ve on the output?
there are a number of explanations for using a multimeter to check transistors, generally you can check then as two diodes and/or use resistance to check for shorts
Ok I will look into checking transistors with the multimeter, thank you for your response. The 94V was positive as referenced to ground (+94V).
so the positive voltage may indicate the +ve side of the rail voltage- so Q330 and associated circuitry- also check the diodes and Q314/Q316/Q310.
check the voltage at D312/D310-should be 1.7v (+ve or -ve) and look for 8.9v at the base of Q212
these will help diagnose whether it is in the input/vas or output stages.
also check Q334- the bias transistor
- NAD 2600 Power Envelope Stuck in Protection Mode
