Hi, my name is Justin and I'm a long-time lurker of diyAudio.
I have a bit of experience repairing audio electronics, but today I've come across an old NAD 216 power amp that has me totally stumped.
This amplifier, sometimes works, sometimes emits white noise, sometimes just buzzes and pops, sometimes only plays through one channel, and more recent troubleshooting has shown a 1KHz sine wave emitting from the right channel amp block output as nearly triple that of the left block output.
As far as I can tell, both the amp blocks and the power transformer are functioning properly, all my troubleshooting has lead me straight to the power supply block, but seeing as how the problems are so sporadic, I'm at a loss as to what to look for.
Both amp blocks are getting a totally even voltage of 61/0/61, at all times, even when these strange things happen.
I have observed that while both channels output the sine wave, right higher then left, after going through the power supply/filtering block again, the speaker outputs on the back measure as left outputting properly, right outputting next to nothing.
Any help on this matter, from schematics to advice would be greatly appreciated.
Hi Justin,
Well, straight forward troubleshooting should have you looking at the feedback network. Sometimes there is a large cap from the inverting input to ground in series with a resistor. It's either open or the solder joint has failed. That would be my crystal ball guess with no schematic to help. The power supply would not seem to be involved in your fault.
-Chris
-Chris
From what I can tell, the power supply, feedback circuitry, soft clipping and crossover circuitry are all on the board marked "power supply ( NAD 216/214 )". I know the problem is emitting from this board, however, it's in a very tight spot and I just haven't been able to get in with my scope or DMM to test anything. The wiring doesn't allow much movement without re-soldering and I don't have a soldering iron here. :/
Hi Justin,
If you feed a signal into the amplifier section, does it come out amplified or the same level?
Have you tried 100 Hz and 10 KHz to see if the loss of gain is frequency dependant?
-Chris
I'm sorry, but people tend to think circuit, not board location.From what I can tell, the power supply, feedback circuitry, soft clipping and crossover circuitry are all on the board marked "power supply ( NAD 216/214 )". I know the problem is emitting from this board,
Make some tests that you can get readings from with the amp in it's normal, together state. Then you figure out what circuit is involved and approach it that way. Can you access the bottom of the PCB?The wiring doesn't allow much movement without re-soldering and I don't have a soldering iron here. :/
-Chris
anatech said:Hi Justin,
-Chris
The signal comes out amplified on the left speaker output, not the right. However, I know both channels do function properly because when inputting a 1KHz tone from my laptop, I can get a perfect and equal sine wave off both the left and right channel direct outputs, just not the speaker terminals.
I've tried 60Hz, 100Hz, 1KHz and 10Khz, and the problems seem to be totally independent on the frequency of the input signal.
I believe the relay is bad, but the soldering below it is a mess as well, and I'm wondering if there is more going on here because when I wired it up to do some testing, I noticed the first two or three amplifying transistors on the right channel amp seem to heat up much more so then the others in the right, or left channels.
Significantly so as well. After playing music for about 15 minutes, the right heatsink is hot to the touch, hotter near the first stage transistors, and the left side is still completely cool to the touch.
Hi Justin,
At this point you need to stop and obtain the complete service manual or at least a schematic for it. Once we have that we can make some detailed suggestions for you.
Something has changed, those parts were not getting hot before. Therefore stop and think it through with the schematic. Also, check your work after a night's sleep.
-Chris
-Chris
I'm not sure if it was getting hot before, I never tested it with enough of a load to tell. However, I did notice the "idle current" trimmer on the right side is set very differently then on the left, I'm not sure if this was intentional or not. I do know that a friend of mine whom this stereo belongs to took it to a repair shop before contacting me, and they were unable to fix it.
I don't know if they would have tampered with that or not.
Hi Justin,
What you will need to do is go back to the simplest things and confirm everything as you go. There may be two or more faults here now.
Step #1. Identify any replacement parts. Make sure the proper ones are installed. If you see ECG or NTE - auto replace. They are garbage.
Step #2. Look for soldering where parts may possibly be installed backwards. Also check for incorrect resistor values.
You need to check and confirm the previous tech didn't make any errors or leave you any presents. Once you have gone over everything that was done before, you can start to troubleshoot your faults. Take it from someone who has made a career of repairing the unrepairable sets.
Right now, your priority is to obtain the schematics. You shouldn't do anything without them.
-Chris
It most certainly has. "Struck by panicking technician". These can be the hardest to fix sometimes.I do know that a friend of mine whom this stereo belongs to took it to a repair shop before contacting me, and they were unable to fix it.
-Chris
anatech said:Thanks Edmond.
Now there are three avenues to explore.
-Chris
Avec plaisir.
Salutations, Edmond.
Strangely enough, I replaced the speaker relay and readjusted the idle current pots, and now it's working fine without any excess heat from either channel's heatsink.
I'm still skeptical though, so I'm going to keep a sharp eye on it for awhile.
Thanks so much for all the help.
- NAD 216 issues
