N00B Question
Hey guys, im very newbie at all this stuff and am currently attempting to build a sound system for my car. I have a few very n00b questions:
1. Watts with Watts??
Say a i have 2 400W speakers how many watts of amp do i need? 400w? 800w? 200w???
2. i Have a vibe cbr10" active (the amp inside is 300W) and it is running through my 4x50w head unit. My speakers are running through the head unit too. Are these 300W of power from my cbr amp added to my 200w of head unit, therefore giving my speakers extra power?
Any websites with answers to simple questions like these for me would help too..
much appreciate the help!
C4SPER
Are you using the line level out to your powered woofer? Then it gets it's 300 watts as the signal sent to it is low level, not amplified.
If you use the amp in the head unit for the main speakers, they each get 50 watts. The two aren't combined except for at your ears. The 400 watt speakers will probably do okay with that but you have to not fall into the pretense that a 50 watt amp "couldn't possibly" blow a 400 watt speaker. It can and it will if you push the amp too hard. That's when you get the "clipping" that sss mentioned. To be very general, it's like the amp is sending out huge bursts of electricity to the speakers (10 to 20 times the rated output of the amp or 500-1000 watts in this case). So be careful not to overdrive the system.
Cal
so, basically, watts doesnt really mean a whole lot?, just dont go stupidly overboard and dont go too underboard either?
i guess this is the case.... is there a ganeral medium i should stick too?
i.e
if i have 2000w worth of various speakers, keep to about 2000w of amp? or say, 2000w of speakers to around 1000w of amp? just looking for a genral rule to stick too.
Thanks for your replies peeps, most useful.
Thanks again
C4SPER
