In anthony N-channel amp does the phase splitter transitor(Q13) need to be mounted on the same heatsink as the output device?
The schematic can be found at:
http://www.aussieamplifiers.com/download.htm
Joined 2002
http://www.diyaudio.com/forums/showthread.php?threadid=5447&perpage=15&pagenumber=4
you shuold read up on this part to understand you posted question
and yes yuo do have to have it mounted to the heat sink. if you dont youll have a nice blown board like in the pic in the link above
Q13 on heatzink?
No, It would not need to be.
Actually it is best to use a separate cooler.
This transistor does not control the idle current.
That is up to what I can understand.
Maybe I am right after all.
