Myths, tricks and hey, that's neat!
Interesting to read this from the other side of the pond. At the same time here in Germany we stared fascinated towards USA with brands like Klipsch, Electrovoice, JBL, RCA, Motorola, National Semiconductor, Texas Instruments, Raytheon... - certainly far above any Grundig, Saba, Metz, Telefunken, Graetz, Siemens, ITT, Valvo or RFT etc.🙂
Tungsram Orion 1937/38. Feedback and feedback.
That answers my question about the patent for amplifier feedback.
That must be one of the earliest applications in a consumer audio product. It's quite convoluted too; there's an inductor in one of the loops. That seems like a bad idea in a high impedance circuit.
The output transformer was a big disincentive to using global feedback. There's two poles to deal with and motorboating used to be a thing with audio amplifiers. Large amounts of negative feedback became much easier to employ with transistorized circuits.
In the 1970s I built an ultalinear amplifier with salvage parts. It was heavily based on a Knight schematic. By using a transistorized power supply, and a much more reasonable 100K input impedance, I managed to make an amplifier that was as quiet as a solid state amplifier (NO hiss, clicks, thumps or hum) without the awful grittiness that most transistorized amplifiers offered at the time.
And it was then that I realized just how important global feedback was in obtaining consistent, repeatable performance. I remember when a balance control was mandatory. Why? Because as tubes wore out, one channel would get fainter than the other until it almost faded away. With global feedback, performance remained consistent until most of the useful life of the tube was already used.
And what's considered high-end there is what counts?
I am a bit confused what you're trying to say?
It started originally with a comment from someone that (global) feedback didn't exist in the 50s and 60s.
Which is just not true.
If that's high-end in some parts in the world or not, isn't
No one claimed global feedback did not exist in the 50’s and 60’s. It was discovered in the 1920’s after all (Harold Black, Bell Labs). What was said is that it was misapplied when the transition was made to solid state amplifiers and some very real examples demonstrating that were cited but I’ll repeat them here:-
1. Distortion wars amps of the 1970’s (TIM, SID).
2. The whole Matti Otala thing. If ever you needed an example of getting feedback wrt audio amplifiers wrong, it’s his papers on the subject. See Dr. Putzeys ‘F-Word’ refutation of the whole thing
3. In 1998 (and others even later than this) Martin Colloms (BSc Engineering qualification I am told) claimed feedback goes ‘round and round’
4. You only have to root around on Stereophile (think of it what you may) to read interviews with designers claiming the deleterious effects of feedback
Let’s not go down the ‘Waly road’ where things are purposefully misconstrued in order to promote argument for argument sake.
Reactions: b_force
Bart Locanthi worked on military servo systems and analog computers in the 1940's and 1950's so he understood a lot about feedback and what happens if you abuse it. The link below is to the JBL SA600 which he designed and it was launched in late 1966. If you look at the circuit (from over 50 yrs ago), you can see that many of the things we consider accepted practice now, he was already doing. Unfortunately, a few years later, Matti Otala came with a story that feedback caused problems by drawing some wrong conclusions. Bruno Putzeys discussed this in his 'F-Word' article
https://hifisonix.com/technical/the-sa-600-amplifier/
Hi Andrew,
Let me share the magazine article on the Locanthi amplifier.
Regards, Pavel
Reactions: Bonsai
Totally agree, although to some extend it's also trying to understand each other.
Which can be quite the challenge wading through layers of being just text only, background differences, cultural difference, language differences, age differences and personalities.
To end on a positive note, even though it can get pretty hairy and rocky here, I am actually amazed how much faster things go than most companies I've worked for.
Which is interesting, because most of them don't have the issues of text only and often there isn't much of a big difference in culture between people.
I beg to differ here a bit. If you have a solid state amplifier with gain, you need feedback to make it usable. Otherwise the result is horrible due to intrinsic transistor transfer function. And you have feedback even if you do not see it at 1st sight, like in the emitter follower with almost 100% voltage feedback. For some strange reason, audiophiles consider feedback only as Global FB from output to input. This misconcept is strategically misused by some marketing oriented engineers. Local feedback has same consequences as global feedback, but it was never demonized. So it goes, lack of knowledge is easily misused.
Another need for feedback in transistor amps is that they often have very high open loop gains that would make them vastly overly sensitive to any input signal. You'd need the feedback just to knock the gain down, if nothing else.
And @Bonsai
My-fi can be pretty pleasing sometimes. 🙂
I sometimes play around with old tube radios, just for fun (plus it's relaxing to work on simple things).
I am always amazed how quickly the masking effect kicks in.
Sure, when you make yourself aware, it's all pretty obvious and audible.
At the same time it's amazing how quickly you get used to it and just enjoy the music.
Sometimes that bit of extra patina on the sound can be satisfying as well.
Very far from proper sound reproduction. Haha
My table radio has its 35L6 output tube set up with just an unbypassed 150-ohm 1 watt carbon resistor to gnd.
