Myryad MA240 service manual
Hi all, my amps not clicking on. When I disconnect the power rail the relays click on, but they don’t when connected. DC is fine.
Hoping someone has a service manual? Maybe even help me diagnose the problem.
Thanks gang 🙂
Thank you very much, I’ll check it out. The board is well laid out, guess I’ll take my time and test things slowly. PSU seems fine and the relay seems to be doing its job. Visually I cannot see any damaged components.
Yes, mine was running pretty hot before hand. I’ll take the board and have a look. This will be great learning experience for me I hope. I’ve built a few projects, chip amps, Salas FSP but this will be my first repair. Fingers crossed I can get it working again.
by experience,check the underside of the pcb,it is very hot under there.
mine is very beautiful above but cooked below
You called it. Looks like quite a few transistors have burnt out. I’ll have to order a solder sucker today. 🙂
Thanks you. I’ll keep you posted. I have to go to work now but will have another look tonight. While I wait for the solder sucker, is it possible to test the transistors while in the board? I’ve only tested with DMM set to diode setting.
Hi, my previous order didn’t go through so I’m putting in a new order today. Solder pump, Capacitor for another project FSP, Bnc to crocodile test lead for signal gen, 8 ohm 150 watt dummy loads and new transistors for my busted amp. Thank god for the old chip amp.
So the transistors that need replacing are before the pre drivers, input pairs or something. I’m not sure exactly there function but they are: 2sc3790 D and 2ca1480 D. I’m attaching a screenshot with details.
Any suggestion for a substitute would be greatly appreciated.
Would anyone like to help me save my amp?
I’ve replaced the regulator Q504 - 503, 505, 506. Q501 and 502. Please see pictures, any advice on how to find the fault please.
