My_Ref problem: DC on output
I was testing a VU meter circuit on my working My_ref rev C amp.
Now I have -29 volts on my outputs and inputs. This is with the LM318 in or out of the circuit. I don't see any burned components, and it happened to both my channels. The +-12 volt is working.
Anyone have any ideas what to check, or what causes this?
Thanks,
Eroc
Like this.
You could use 1N4001 or similar. Just need adequate surge overload rating.
Neurochrome.com
Joined 2009
If you had enough current flowing in R11 to fry it, a pair of diodes won't help. They'll prevent the resistor from frying, but that'll likely just cause something else to fry. There isn't supposed to be any current running in R11, so I'd figure out where that current is coming from first.
Tom
