Heres my exprience with mathcing trasntiors, I have matched a tip41C and tip42c today, precisly matched.
After putting it into the amp I can hear a improvement in sound, sounds a little bit more crisp and clear , and also more clean compared to before.
Although Its only two transitors matched and the outputs and dirvers aren't matched it makes a diffrence to sound.
Cause I am a sensitve guy I reckon its a massive diffrence, slightly better is big to me.
Whats your exprience and or oppnion on matched trasnsotrs and mosfets?
I have tired using diffrence operating voltage 45V vs 52V and theres a diffrence in the two gains when matching (BC voltages on both varry more voltage accross my load changes, not close to 0 mV any more)
, So if its matched at 45Volts its not matched any more at 52V, or not precisely matched
So its improtant to use the voltage your going to operating the trasntior with and use the biasing your going to have to match the trasntistors.
A matched trasnsitor using 12V may likely not be a matched pair once you use 50Volts with them
Heres exctally what I did to match my stuff, Find two matched resistors for bias, connecting a resitor from C to B.
Resitors connected in common collector mode, 1X pnp and npn using duall supply, connect Emiter legs together through a 4 OHMM 5w wire round resitor, and connect other end to ground. Hook everything up and measure voltage accross 4ohm to be closest to zero volts and have the BC voltage simullar on both trasnsistors. Wen't through about 8 pnp transistors and only two matched, 4mv and 1mv at .Worst I got is a varry of about 22mV at load, which is equivlent to 22Volts diffrence at BC voltages.
I get about 45Volts with my protection bulb on and 52Volts without the bulb, and gain changes once the voltage or bias varries
If I was to match a common base or emitter, I would match bias resitor or zener/diodes, depneding on which your gonna use.
Also you should use a PCB, and put wires comming out of the commponents that you need to connect to the trasnsitors, as you solder resitors and they have a temp change, they can degreade and could cause them to change values and the resitors don't match any more
Then measure BE to be same,
(not entierly sure my self which is equivlent to BC voltage in common emitter and base set up)
The load resitors also need to be the same, matching some 10K reistors. As common base and common emiter use the collector as out put, we cannot short them toghet to get zero volts(If you don't belive me you can try, I think the two trasnitors will blow up, cause I tried it before), other wise it will blow up, so they way i match them is to find same BC voltage
