Hi Casiomax...
Yes it is the same design from Alex...
It's the kind of PCB that he offers for those who want to install the PCB on the big chassis... not the slim one like I have... which then Alex suggested me to re-drill the heatsink so that the PCB ca be installed within the slim chassis...
As for toroid rewinding... sorry, I don't know any....
But probably you could check with Alex?
Dino,
thank you very much for the info. Above I read your PSU config, would you share the PSU schematics?
appreciated it.
thanks again
appreciated it.
thanks again
hmmm ok no problem.... i know it's take risk n time hehehe
btw can't u share what component u used/merk/type that i can follow like:
C1 (2,2-4,7 Bipolar) ? Tipe/merk?
C2 220 PF? Tipe/merk?
C3a,3b,5? merk/tipe?
Resistor ? merk/tipe?
where u buy Vishay Telefunken SF4007 n
2.2 uF Polyfilm? i'm difficult to find that part, maybe someday i need ur help to buy same parts as you.
btw:
6. I glued some of the AC cables to the chassis...?
u mean grounding, right? or fire/netral hihihi
what glue u use? (lem bakar?)
btw:
Re: Re: Second Prize
maybe u can ask about rewinding ur toroid at forum.chip.co.id...
sound n audio sub thread....
hi dinocasiomax said:
I have a few toroid transformer, but all of them are 117VAC primary, back when i was in sumatera, our mains were 110VAC, and this transformer I bought when i lived there. So do you happen to know anybody in Jakarta who can rewind the toroid?
thanks
casiomax said:Dino,
appreciated it.
thanks again
Please find attached... I hope it's not confusing as I re-draw it based on an available schematic...
sneih said:hmmm ok no problem.... i know it's take risk n time hehehe
btw:
C1: 2.2uF cap is not polycap.. my mistake.. those are MKP made by Audiophiler China, cheap.. IDR 4500 a piece..
C 220pF: I decided not to instal it... (cause I didn't buy it.. hehe)
C3a, 3b and C 5: all are Nippon Chemicon 100uF/50 V
Resistors: for the feedback resistor I use Riken Metal Film others are generic Metal Film...
(but actually I want to try with Holco resistor.. as I like the other GC LM3886 I built for my friend.. using the Holco resistors and it sound different.. well.. probably on my next GC...)
SF4007 diodes: bought via Singapore website (forgot... its either Farnell or RSonline..). Was actually leftover from my previous DIY project: replacing the diodes of my NAD CDP. Later I found out that these diodes are available in the city... silly me 😛
Glue?: It's the usual hot glue (lem bakar...) no, I applied them on the loos cable between the AC inlet and the Power On/Off switch.. initially applied this approach just to have a tidy layout.. hehehe... 🙂
Thanks.... and Happy DIY!!
only 1pcs riken? hmmm save money,right!!
btw i going to test my GC... i confuses it's good or not hehehe!!
question:
how much dc offset maximal?
how much dc offset recomended?]
thx
nb: where do you live friend?
question:
thx
Dino-Indo said:Hi Sneih...
Feedback Resistor is installed next to LM3886 chip.. it's the R5 on the PCB... (see attached) I used Riken Metal Film 22K 0.5 Watt 😉
om Dino,
does your configuration produce a slight hum? i dont use PCB from om Alex, but instead, I solder components directly to LM3886 pin, and make a start ground from pin7.
I powered the amp with +/- 32volts, btw I am using a standard 3amp CT transformer.
Hi Casiomax,
Yes.. it did produce very slight hum on the left channel.. but I only can hear this when I put the potentiometer fully open and I put my ear very close to the speaker....
But then I re-do the grounding and the hum has gone... 😀
If possible, I suggest you to apply put a grounding cable from the ground of your power supply capacitor, then solder this grounding cable at the same point in the Chassis with the Star ground of your LM 3886 chip 🙂
If it still produce hum, then probably you should check and try the approach that I did as I mention in this post:
http://www.diyaudio.com/forums/showthread.php?postid=1451754#post1451754
Hi Sneih,
I live in Menteng Dalam, Tebet area, Southern Jakarta... 😀
Hi Sneih,
we want to hear about the successes as well as the problems.
Hi Andrew,
😱 Geeez.. 😱 what I did was just making sure that the 'flow of the signal' right from the input to the output did not produce 'ground loops'...
See, on my first attempt of my GC I used many cables to 'channel' the grounds of each LM3886 PCB to arrive at the same star ground at the chassis... 😱
But on my second attempt GC (with the new PCB) I use only one cable from the speaker output ground to the chassis 😀
On both approach.. I applied the grounding circuit as suggested by Rod Elliot on his website (http://sound.westhost.com/project04.htm) .. my big thanks to Rod !! 😀
Hi Sneih!! Thanks !! 😀
AndrewT said:The Thiele network on the output does two jobs.
1.) it provides a defined load at high frequency.
2.) it attenuates back emf/RFI that tries to enter the feedback route.
Hey andrewt i was searching the forum about Thiele Network and i found this post, can you please tell me how you calculate the values of Lo and Ro to design the Thiele Network at ehe output of the amp? i cant found why is used 10ohms.
Thanks in advance.
http://www.diyaudio.com/forums/showthread.php?postid=1475396#post1475396
recently I have been playing with using both the before and after Zobel forming a Pi filter. Setting the Ca = Cb = 47nF seems to give good values. R2 = R1b = 4r0 and R1a = 8r0
Dino-Indo said:Please see the attached picture for the second attempt of my GC... with less grounding cables... (please refer to the red circles)
I noticed that in your PSU you dont add any Res to discharge the Caps when turn it off.
Is not good to do that?
- Chip Amps
- My version of GC, a LM3886 based
