My TPA3122D2N BTL proto
Seven hours later and I now have a working TPA3122D2N amplifier running BTL 😀. I followed the eval board schematic.
This little baby is sweeeeeet. I built up a TPA1517 chipamp yesterday and this little class-d totaly crushes it. I've been running the TPA3122D2N into an 8R bridged load @ 14v for over an hour now and the thing is barely warm. I was running the TPA1517 in the same configuration yesterday and the IC got extremely hot, even after I attached a heatsink. The TPA3122D2N sounds better to my ears as well; very tight clean bass.
Now I just have to build the other channel.:xeye:
1" x 2"
Very nice PCB design, I have 5 of these just sitting at home.
Nice to know that it sounds sweeeeeeet, I also built the TPA1517 (class AB IIRC) so your feedback is appreciated.
Once I complete my Amp6 that will probably be the next one in line.
Eric
Eric
Thanks, I utilized a continuous groundplane on the top layer and it seems to have turned out well. I have to press my ear right against the tweeter to hear any kind of background noise.
It really amazes me how cool this chip runs. It's obviously a night and day difference when compared to a linear amplifier like the TPA1517, but it also runs MUCH cooler than my AMP32. That's surprising considering it technically has lower efficiency.
This design was just to test how the small TI class-d perform. My next project will be with the TPA3106D1. It will be a bit harder to work with, but it doesn't require a differential input for BTL operation and it's capable of more power.
My samples of these puppies just showed up - Kudos to TI for making a switcher in a dip package. I notice that these are not rated to run 4 ohms with a 28 volt supply - anyone know if it is possible to parallel the inputs and outputs (prior to the pi network) to up the current handling (in mono, of course).
M
M
I paralleled the inputs and outputs and it seems to work. If only one input is connected with the outputs paralleled the amp just clicks though. I would test it at 28v with a 4R load for you, but I built the board with 16v capacitors.
I just finished making my first TPA3106D1 PCB. I've soldered the IC on, but I can't finish the board yet because I'm all out of 1uF 0805 capacitors.
There is a pad under the IC that connects to the top side ground plane both electrically and thermally. I don't have a way or method of soldering PowerPADs, so I just used a dot of thermal compound. I think with all the other pins that connect to the ground plane it should be fine.
Thanks guys. I have a small toaster oven and contemplated doing the thermal pad that way, but I don't have any solder paste and it isn't something available locally. I'm too cheap and impatient to order it by mail. I think it should be fine with the combination of thermal compound and the pins connected to the ground plane.
luka said:
Hi
Solder paste? nah didn't you read my thread? I used normal solder, which melted nicely between board and IC, making great termal conduction
I read the thread, but I'm not sure exactly how you did it. Did you melt some solder to the PCB first, or did you put some of the un-melted solder wire between the board and the IC?
I managed to scavenge enough parts to complete a board. I like this one even better than the TPA3122D2N. I also love when a project powers on and works the very first time.😉
Hi
Damn that looks nice
Ok let me gide you for any later project you would need this
You will be able to see first pic, I used that as test, some broken fet and unused PCB and do this:
1. Make sure your solder material has a melting point that is not higher than 190C. Most 60%Zn 40%Pb will melt at around 180C. (My was one of them)
2. Heat an oven to about 230-240C (I think I had 230, and was enough, or did I had only 220, it is stil more then enough)
3. Scrape of the solder mask in the rectangle in the middle of the chip position on the PCB with a sharp knife. Make sure you remove all solder mask varnish in this area. (That is if you have factory made PCB, for home you don't have to do anything)
4. Place about 20 mm (3/4”) long bit of solder with a diameter of 0.6 mm or the equivalent amount, bent into a circle, on the cleaned PCB area. Place the PCB in the oven and measure the time it takes before the solder has melted and flowed out on the solder area. (This was for TK2350, so you can use diffrent wire lenght and it doesn't have to be 0.6mm, but my was 0.7mm) It may take about 2-3 minutes.(it was in that time somewhere)
5. Remove the PCB from the oven and let the PCB cool down.
6. Spread some “no-clean” non aggressive solder flux on the solder area. A solder flux pen is handy for this. (I used normal whatever I use normaly, no problems with it, just very small amount)
7. Place the chip perfectly in place on the PCB. Make sure all chip leads are aligned to the solder pads of the PCB.
8. Place the PCB in the oven and allow as much time as before, but add 20 seconds for the chip to heat up. After this time shut of the oven power, open the oven door and gently fan cool air into the oven. (I have waited about 30s, and then slowly and easy took whole board leveled out and put it down to cool)
9. Let the PCB cool down and inspect it.
10. If everything is OK, solder the chip legs to the PCB pads.
luka said:
Hi
Thanks Luka.
I'm kind of glad I didn't solder the thermal pad to the PCB now. I made the stupid decision to try and ground the negative input while the board was powered up. It didn't like that and decided to throw the rail voltage at my test speaker.:bawling:
Oh well, 15 minutes and a fresh IC later it is back singing again. I think this amp might work better with a differential input, even though is doesn't need it to work BTL. I will give it a try and report back.
It seems I have a small inductor heating problem with the TPA3106D1 board. I didn't notice it at first , but they are definitely heating more than the ones on the TPA3122D2N (which don't heat at all really).😱
I know a multimeter isn't exactly the correct tool to trouble shoot a problem like this, but I did measure some differences between the two boards with it.
AC voltage across output inductors:
TPA3122D2N = 1.938Vac
TPA3106D1 = 2.664Vac
AC voltage from output to ground:
TPA3122D2N = 0.003Vac
TPA3106D1 = 0.078Vac
You can see both reading were higher with the TPA3106D1. Both boards were being powered from the same 12v battery.
The only thing I did differently with the TPA3106D1 board is put one inductor on each side of the board and I used 1uF WIMA MKS capacitors for the output filter instead of 1uF X7R ceramics. Could either of those things cause this problem, or could it just be a layout issue?
A small dab of lead free solder paste is what we use for the pad,
but if you are doing this at home I would definitely use LEAD....
The machine can do lead free just fine, but when it come to the
manual rework. I dread the lead free on the heatsinkless PCB,
where the board itself conducts the heat... The difference from
just enough heat, and burning up the board is a very fine line.
You need something (like hot air) to warm the board from the
back side, and the iron (or slightly hotter air jet from the top)
to do the fine local melting....
I don't recommend thermal compound, cause you will still need
to clean the flux from between the pins, and this will wash out
any grease you may have tried to substitute.
The DIP is so much easier package for the do-it-yourselfer...
But I even the DIP needs to be soldered too, I wouldn't risk
a socket to conduct the heat...
Surprisingly it didn't. After I finished soldering the IC I had submerged the board in alcohol forgetting that the thermal compound was there. When I killed the IC and had to replace it all of the thermal compound was still there. I didn't submerge it again after the replacement; I just used cotton swabs to clean the flux.
I wouldn't touch lead free solder if I was given a truck load of it for free.😉
