Hi all. I want to show a "gem" that I built, based on a chassis of Technics SA-5551 and based circuits LM3886 and preamplifiers circuits Rod Elliot. Each day a photo and show the steps of construction. Greetings José
Thank you very much for the compliments. no eletronic component is original.Was based on a TECHNICS "VINTAGE" THE YEAR 1975IN VERY GOOD CONDITION OUTSIDE, BUT WITH DEFECTIVE ELECTRONIC (AT THE TIME WAS 130 WATTS P / CH).Were dropped ALL ELECTRONIC COMPONENTS, LEAVING ONLY THE CHASSIS, ALUMINUM FRONT, POTENTIOMETERS (Matsushita / Panasonics), selector switches, BACKLIT DIAL, THE KEY ON-OFF, BACK WITH ALL FITTINGS, DECK SUPERIOR, TO WHICH IS BLACK VINYL BAG THAT POSSESS THE FACTORY AND YOUR replaced by LAMINATED WOOD, LUSTRÁNDOSE.-BE BUILT: THE PHONO PREAMP WITH COMPONENTS OF HIGH QUALITY ROD CIRCUIT BASED ON MODIFIED ELLIOT PCB FOR EACH CHANNEL USING A BURR-BROWN OPA2134 (AT CHANNEL ORIGINAL shared the RL-INTEGRATED) JUMPS THROUGH WITH VARIABLE GAIN Internal (40-56-60dB) which allows the use of capsules COIL AND MAGNET MOBILE;**********************************THE PREAMP LINE IS ALSO BASED ON CIRCUIT IN MODIFIED ELLIOT ROD PCB;***********************************SELECTION OF AUDIO IN A BANK IS BASED ON LOCATION OF 6 RELAYS WITH YOUR BACK TO MINIMIZE THE WIRING CONNECTORS, ELECTRICALLY CONTROLLED WITH ORIGINAL KEY IN THE FRONT;***********************************POWER AMPLIFIER INTEGRATED IS BUILT WITH TWO LM3886TF, USED FOR THEIR BRANDS HI-END ultra high performance (AUDIO ANALOGUE VERDI; JEFF ROWLAND, CAMBRIDGE AUDIO, AP-2410 JATON A operetta, EG.). MOUNTING PLATES SEPARATED, LARGE HEAT SINK AND SOURCE OF PERFORMANCE audiophile WITH COMPONENTS OF HIGH QUALITY (TRAFO OF 280 WATTS, FOUR CAPACITORS audiophile THAN 10,000 MICROFARAD IOS EACH; BRIDGE DIODE HIGH SPEED AND CAPACITY TO HANDLE 35 AMP). ALL CIRCUITS WERE ARMED WITH METAL FILM RESISTORS 1% TOLERANCE; CAPACITORS PANASONIC, PHILIPS, ELNA and WIMA.CAN BE SAID TO BE MOUNTED INTEGRATED AMPLIFIER DUAL, HIGH PERFORMANCE WITHIN A FRAME OF A RECEIVER.AUDIO SIGNAL WALKING TOURS ALL GOING ONLY FOR A POLYESTER CAPACITOR (WIMA, Germany) DC decoupling OF BETWEEN PRE AND POWER.All electronics are assembled in FIBERGLASS PLATES.COMPLEMENT AS A PLATE WILL BE ADDED TO A TUNER TUNER PHILIPS (HOLLAND) with excellent sensitivity and selectivity (AM-FM TUNER PHILIPS 194), THAT HANDLES BOTH FRONT vumeters TUNING AND SIGNAL STRENGTH, ORIGINAL TECHNICS.
