Ok, well I've seen a lot of really great subs on these forums. This may not be one of them, but I think it sounds pretty good. It's basically a 24 inch cube 6.8 cubic feet, 3/4 mdf except for top and bottom. I used 1 1/8 inch dowels for bracing, the front baffle is 1.5 inches. The speaker I'm using is a PRV 15W700 powered by an Artison RCC300 sub amp. For damping I used 7 lbs of polyfill. My system is a Denon AVR 710W with Pioneer BS22 series for front center and the other sub. Still have LG HTIB for rears. Due to my poor woodworking I covered the sides with beadboard and the top with pine. I also covered the corners with aluminum angle painted oiled bronze. I stained the whole thing with 3 coats of Minwax Espresso and spray satin poly. I haven't done any room measurements or anything like that, but I have been very pleased when watching shows and movies! Some of these pics are from my phone so they may be low quality.
Mostly Done
Bracing
Beadboard on sides, front veneered, top pine boards
Stained and in place
Different Angle
Mostly Done
Bracing
Different Angle
If you have script blockers running (which is generally good), you might be preventing the script that auto-resizes images from running.Your images are too WAY large to fit the page![]()
- Subwoofers
- My Sub Build
