Alright guys, i have an Alpine head unit with 2 pre amp outputs. I have a 4 channel amp already in my car, hooked up, working and everything for my 4 speakers. So the 4 channel amp is all done with.
I have a 2 channel amp to power my subs, and distribution block, and a cap. How would u guys set the new stuff that i have up, and keep my old stuff there to? Just how would i add it in for the easiest cheapest install? (power wire to distribution block then split to the cap an amp? or what?)
Plus, for my 4 channel amp, i have a 60amp fuse up by the battery, and my 2 channel amp ill do the same. My 2 channel amp has 4X 25 amp fuses on it. Ill have the 60 amp fuse up by the battery, what size should i put in the distribution block?
Thanks a lot guys in advance.
