So I added sand to my speakers. The speakers are covered here
Something weird happened. I have been burning in my speakers/cables/xovers and gear for weeks. It was all very stable burn-in wise.
I put in 70lbs of sand in the speakers. They sounded better right away. I left them playing for 3 days and they sounded WAY better. The sand had "burned-in". It was a big change. It was not subtle. So I guess the billions of sand particles settled in the 3 days and are working better. Crazy as that sounds.
I really never imagined sand could burn in, but it can...
Sun Spots.
Ahhh.. Of course.. I should have checked the solar flux Today's Space Weather
That you can reliably ascertain so called "burn-in" over a number of weeks isn't sensible at all.
Oh sure it is. Ive been doing super high end systems for 2 decades changing out gear/wire for clients often and yea no doubt burn-in occurs. The effect is far more obvious as you go up in quality of gear. Sometimes its just mind boggling how much a difference can occur. Long line level runs are really prone to this. But drivers in speakers and high end crossover parts like poly caps also burn-in for sure. Now over weeks, I dont listen every day. I let things run for days and come back and listen.
And by burn-in im not talking subtle. Like suddenly there is a instrument you did not even know was there.
Even complete novices who have never listened to high end gear hear burn-in. I had a friend who had never heard high end gear and was over at the start of my speaker project and listened then came over a week later and said "Wow, they sound better what did you do ?" when i had not touched anything. Literally I did not touch anything.
Now this sand... That took me by surprize. It does make sense. All the particles setteling into place and dampening better. It was still surprizing.
But yes. I agree, Solar Flux..
the EE's I worked with at Tektronix and Dolby Labs all seemed to agree that the audio memory is pretty bad. I'd ad to that, that our hearing is substantially inconsistent, but we adapt enough to not realize this. An Audiologist (medical) told me that it's normal for the inner-ear chamber to buildup pressure over time, not enough to be obvious, but enough to affect our impression of a speaker. This is something that occasionally gets normalized, and creates inconsistency in our hearing. I think the importance of burn-in is exaggerated by many.
The only "burn in" occurs in the brain of the listener. Human beings are notoriously unreliable in their perception, and not just hearing. There is so much research, available on the web, that shows peoples' absolute certainty about seeing or hearing something is wrong when shown what they actually saw or heard. The real of intellect is the recognition and acceptance of your own fallibility, and that is a step most people are either unable or unwilling to take.Oh sure it is. Ive been doing super high end systems for 2 decades changing out gear/wire for clients often and yea no doubt burn-in occurs. The effect is far more obvious as you go up in quality of gear. Sometimes its just mind boggling how much a difference can occur. Long line level runs are really prone to this. But drivers in speakers and high end crossover parts like poly caps also burn-in for sure. Now over weeks, I dont listen every day. I let things run for days and come back and listen.
The next problem is when some one declares absolutely that their perception is correct. Generally, those people will not accept that they are wrong despite absolute evidence to the contrary. It is a bit like declaring a disease is cured by homeopathy when the "cure" is only water with a bit of sugar in it. Again, despite physics and chemistry having proven that Avogadro's Number (6.0221413e+23) is a certainty, some are convinced that a dilution past that number will still yield a physical presence of the original (though still dodgy) compound.
Nothing can shake the True-believer syndrome - Wikipedia, the free encyclopedia.
Abs
I got it...why doesn't one spray some of that "Spray adhesive"...the one that's used to lay down carpeting in cars?? Spray some on your favorite driver, sprinkle some Talcum powder immediately on the cone? Cornstarch, graphite...work your way up to sand. Measure the fantastic.........Oh wait, don't measure, God forbid............just listen to how much better it sounds! An earthy, particular type sound it emanates. You could charge $50 for the select Tahitian sand....no, no Bali for that "tropical" sound.
_______________________________________________Rick..............
I don't know how it is with others - on my side it is because my ears are already burned in for ages and my memory is so bad that i can't remember
perfectly exact how the sound was 10 seconds ago. Many times i only get the feeling that there is sth different. Most times it is also hard to decide,
for me, if it is only different or better or worse, cause what i like depends also on my moods. What catches me now may be different after i get used to it.
If there is a burn in effect it will simply happen while I listen to music and it will also happen to my ears.
Anyhow, I don't think its a bad idea to do sth with an otherwise unused cavity. Even if it did not work out as expected it is worth a try.
In the end it only counts what makes us happy.
Oh - i remember some real burn in effect! I have an old Marantz 2265B that i use extreme seldom. Sometimes the speaker-relay contacts need some
burn in because there is no sound at low levels. After some serious burn in at high levels it works again for low levels. At least for a while...
BTW. I don't think that Australian sand is a good idea. Somewhere i heared that it may lower the speech intelligibility
They heard the change in barometric pressure. The changes you think are happening are nonsense.
Adding 70lbs of sand is changing the volume of the enclosure. This is also the change you are hearing. There is no burn in occurring.
- My sand "burned in"
