My Russian SET
with fuses installed, power to the output traffo and output tubes are complete....the 3 minute delay timer shorts out the 12k/5W soft start resistor...this resistor is in series with the main B+ ac supply....voltages ramps up to about 100 volts and stays there until the 3 minute timing period is reached, this protects the output tube from thermal run-away, at the same time that the plate B+ is ramping up, the negative bias voltage is likewise ramping up and settles to a value around -75 volts....these steps ensures successful turn on of the amp....
at the end of the 3 minute timing period, the relay closes and the 12k resistor is shorted out thus the B+ finally ramps up to around 210volts dc.....it takes another 5 minutes for the plate current to reach about 200mA....i recommend to wait for 10 minutes before music is played to give time for the amp to settle down to business....
i set the bias pots for this plate current level and bias drift was observed...i am happy to report that drifts were minimal and after 2 hours the bias current actually goes down a bit by around 10mA....this is normal as plate voltages in triodes have an effect on plate currents.....
i also observed that bias changes were caused by changes in line voltages.....
set-up for final adjustment to bias the output tubes.....
with my power meter monitoring the ac input to the amp, power factor was at 92%.....
total watts measured at 218watts...
line current....
thermal scan of the bulb at socket side underneath the chassis, i have installed fans running of 7 volts dc to move a bit of air underneath the amp when bottom plates are installed...
thanks guys, i am excited about this design....the final operating points and power consumption predictions were spot on, computed versus actual.......i am happy....😀
the power trafffo is a little warm even after 3 hours, only the tubes are hot....
as predicted, the total power consumption was around 220 watts...so that at 20 watts music output, overall efficiency is a mere 10%...
Hi Tony,
do you have any concerns about that? 😀
Otherwise... my congrats! Great build!
none, i have grown to respect Russian tubes ever since i made my first 6H23 preamp....over a year ago.....
and after over 30plus years haitus, i ma making tube amps again, i am retired now and i know that i have to keep challenging my mind....an this is my way of doing it...😀
4P1L parallel SET
2nd Russian set with the 4P1L paralel singel ended triode...
paralleled tubes were baised to mimic a single 2A3 tube,
input tube was 6j9 triode wired, buffered by a 6N1P in a broskie cathode follower driving the palralleled finals grids...
the 4P1l filaments are run DC at about 4 volts...
and was very quiet and no hint of microphonics....
