HELLO MIKE <> Thanks for the reply, EVEN if it isn't exactly music to my ears... What you told me parallels what I feared before starting on this, except I was thinking along the line of "poker chip sized" particles... But I decided to go ahead after finding an RCA 2.2" LCD hand held on Ebay, and buying it for what I considered to be a "song"... Maybe there will be some sour notes in that song!... It does have higher resolution than the one you were using, and I only intend to blow it up to 60" wide, so MAYBE it will be something I can live with... I already have several slide/film strip projectors, so this won't end up as a major investment... If you don't wet a line, you won't catch any fish, so I'm going to go ahead just as planned and keep my fingers crossed... As I said on the other board, if nothing else, this will be a learning experience!... AND what you already proved is that this is a valid idea, and if I find as you did, that the resolution is the limiting factor, then I will dig further into finding something of the right size that DOES have enough resolution... Again, thanks for the reply, and I WILL bring you up to speed when I have something definite to report... ;-}
HELLO MIKE <> Well, I told ya I'd let you know the results... In a word: DISASTER... Before I butchered up the hand held to get the LCD out, or the the projector to accept it, I rigged up a bazooka tube with my lens, and projected a wimpy, but revealing picture using fresh onboad batteries to light (dimly) the image... To enlarge my 1.75" wide image to 60" wide, would require 1,200 magnifications, and I could never even get close with this setup, but I did get about a 12" image, which revealed the expected, serious screen door!... At 5" the pixels would be the size of a saucer... RIP mini LCD projection system!... Nothing we didn't expect, but still somewhat a disappointment... Thanks for your input!...
I'm going to try this next week with my Casio 2.3" screen and a similar projector. I will create a thread with results and pictures.
I expect for it to be watchable and brighter than my previous cardboard box attempt.
This is what I tried for my first project...it was fine as long are as you are a Gerorges Seurat fan, Otherwise it was a waste of time and a perfectly good handheld tv 🙂 I would seriously suggest going for a normal size panel and overhead solution. Of course you could invest in a really high rez small lcd, but then that would be more expensive than an aveage commercial projector.
bulb realy 25hr live span?
I bought myself a similar projector (enna 300) and it also contains a cwd lamp.
Do you know if these lamps really only live for 25hrs? If so I could better look for some other option than this slide projector. Maybe i will then use the optics only. (there nice 😀)
My old projector has been going for years of little use, but I guess it depends on the model and bulb used
