I haven't posted in awhile and I figured I'd better say something.
I now have the cooling system for my 7200W amp all done. If only I had an 8x900W into 12ohm double-barreled MOSFET hifi amp to go with it! I guess now I've got a lot of thinking and a lot of prototyping to do. (no way I can afford Electronics Workbech
)The OPS will be a lot like the Leach Superamp, and I suppose my first prototypes will be a lot like it all the way through. Unless of course someone has a better idea, I'd be really glad to hear about it. These channels will have something like 3 times the power and nearly twice the supply voltage of the Superamp, so It will be a challenge for stability and performance, I'm sure, and slew rate may well limit it's high freq. performance, but I might be able to pull it off anyway. It'll probably be frustrating as hell, hopefully I'll have the patience to finish the project! (I'd better, I've put a lot of time and money into it already.)
I figure for testing I can bring the voltage up slowly with a large generator, which I might be able to get.
P.S. I almost have a channel of my Leach Amp done, I'm just waiting for a few back-ordered capacitors. I'll keep you updated and should have pictures of it before too long.
