My project guitar Ibanez RG550 to Custom JEM77
In this project, I used 3 pickups DIMARZIO
DP215
DP158
DP116
I replaced the ton switch capacitor 22NF
capacitor of VISHAY 22NF
in the Volume Switch 500k I changed the capacitor 330PF
to Resistor 130 KHOM In series
capacitor1NF LCR
Now when I lower the volume
Guitar switch
There is no decline in the quality.
The internal wiring of the guitar was replaced with
Auric Hookup 18 AWG wire
the dimarzio pickup dp116 Connected in single split coil
Red and black wire connected
Green and white wires not
Only one coil runs
The end result
Guitar sounds amazing
DP215
DP158
DP116
capacitor1NF LCR
Guitar switch
Only one coil runs
The end result
I solved the problem that many people with pickup DIMARZIO DP116
HS-2.
Always position 2 and 4 sound weaker.
I managed to solve the problem.
from the dp 116
The red (hot wire )connect to the common ground.
ground wire to the common ground.
And the black wire to switch pot.
I did it according to the drawing of Ibanez JEM 555
Now all the 5 Position
Sound the same level .
Ibanez.com | Wiring Diagrams
HS-2.
from the dp 116
Now guitar sounds perfect.
I going to start drawing and painting project on the guitar body.
I drew a sketch using a graphics tablet with Photoshop.
Now remains
to Start the
The real painting on the guitar
it's Good that I am i painter..lol
Now remains
to Start the
