my own pga2310 pre-amp :)
I have a problem with shut down in OPA548. It works as -15V supply. I take 2.5V reference from TL431 and OPA inverts it with gain = 6. It works good. But I can't shut it down. I used the circut from the datasheet with dual supply mode. The e/s pin is at the same potentian as negative rail, so it should be good, but output voltage changes then from -15 to -12 and I can give quite a lot currnet.
And another question. How can I shut down reg1117(3,3V)? Any idea? I feed it from 5V regulator which is enable all the time.
