Wow!!! I can't believe that you made a TAS5630 board with single sided PCB!Hi everybody,
This is my working, very simple Class D Amp capable of delivering 300+300 Watts RMS in 2 Ohm.
However due to unavailability of a heavy power supply and a good mixer, I have tested it on Soundblaster soundcard with the following data:
Voltage 32.5 Volts
Spk: 4 ohms 12" Subs.
Output : ~150W in each channel
Configuration of chip: stereo BTL mode
Board size: 80X60 mm
It is built with few changes in original Texas Instrument application note.
Please note that however TI claims the IC to be operated safely under 50 Volts, but never use more than 35 V with a 50 Hz transformer OR 43 Volts with a SMPS. Else you will burn the chip.
Please Email me if intrested in schematic & PCB layout at akjain2007@dataone.in
Thanks,
Gaurav Jain
Please continue your good work 🙂
....in hope to see your future designs ...
Thanks!
Hamendar
Every thing is in the thread. see post # 23.
Further, if you dont have enough technical knowledge of class D's, dont even think of making this amp because it requires much skill and knowledge to make it working (rather, sound it) otherwise you will only mess up with a lot of oscillations and burnt chips.
If anything is wrong in design, the chip simply keeps its circuitry dead and you will be unable to hear any thing.
I can also make PCB for you if you like the design.
send me email - akjain2007@dataone.in
Thanks.
Gaurav
Please call me at 09480556355, I have some specific questions about this amp, or let me know your number so that I can cal yu
