my new diy speakers project
hello,
I had made many loudspeakers before. this is my new project. 3 way loudspeakers with seas excel drivers.(w26fx001,w15ch001,t29cf002) They are not completed yet. I have almost made the enclosures. they are made from polyester fiber, plywood and MDF. The crossover will be inside the granite base (not on the photos). I have spent about 6 months on it by now. I will update this post when i 'll have completed the speakers.What do you think?
Is this really new? Because I've seen another "nautilus clone" that looked nearly identical, also using Seas Excel.
But whatever, that's a heck of a lot of work for the cabs, hope they sound as cool as they look. Be sure to cover the tweeter faceplate in thick felt as it looks like you're using a worst-case diffraction scenario for the tweeter (the other drivers should be okay, especially the woofer)
Note how in the B&W Nautilus, the drivers are large relative to their mounting surfaces, as it is with your woofer, where there's a minimum of "Baffle". A circular baffle has the same distance from the diaphragm to the edge at every point on the circumference, so you get one very heavy diffraction mode. There's quite a bit of documentation on the effects of surface mounting vs. flush-mounting dome tweeters, you can consider this as a worse version of surface mounting. By using felt, you absorb the energy that illuminates this edge, so there's a largely reduced amount of energy to excite the diffraction modes. This also helps reduce off-axis energy somewhat in the crossover range to the mid, which is a good thing in this and most cases.
here are some build pictures. Many thanks Badman for the explanations.
hi,
today i finished the crossovers. I have also painted the enclosures. i am posting some photos. Later i will upload better photos of the completed speakers. 🙂
the shells does not look so creepy. I uploaded some photos with the drivers in. I am so curious about the sound. tomorow i will complete those speakers and will have a good listen.
finally finished
After a 6 months of work (every weekend and almost every evening) i finally completed the speakers. I must say that i will not do something like this again.🙂 The sound of those units is wonderfull. The bass don't go very low but is very good and stiff for this size closed type shells. The mid-high are very detailed. There is a big difference compared with my previous speakers whitch have bigger volume and dual bass Audax 8'' drivers and Morel tweeters. (there is also a big difference in the price of those units). I have completed the AV400 power amplifier to drive those speakers (http://www.diyaudio.com/forums/solid-state/191130-finished-av400-help-problem.html). It seems that they need powerfull amplifier as they are only about 86db/w.
I am very happy with the result. Optically the shells are a little strange but i can live with that. 🙂
