Just a quick input, I'm the guy with the Enabl'ed stamped frame AN super 12's.
After reading on various forums, for more than 2 years about the AN line and most importantly BudP's very positive review of the Super 15, I think the super 12's just seem to be the runt of the litter....
I guess I just picked the wrong one out of the line.
Do yourself a favour. Life is too short to worry over $400. Some people spend more than that on crossover components.
Go buy yourself a pair of the AN15s. You won't regret it.
Let me know. These are probably my next purchase.
I found the CD case but can't find the bloody CD.
Need to keep looking
Joined 2009
Joined 2009
I bet they have a higher qts than the .483 spec
why? - I thought speakers with large Vas usually have low Qts and this driver has a large Vas
I read somewhere that Qts is inversely proportional to the square root of the compliance. Vas is proportional to compliance.
I know a German site that tested 2 of the an10 qts around .411 while the website lists qts = .278
Not really a big deal, but it would be nice. And yes there is the 10 percent fudge factor for their manufactor.
8ft3 tuned to 30hz.
Or open baffle, big as you can trading the wall bounce though.
Norman
8ft3 tuned to 30hz.
Norman
Joined 2009
Joined 2009
The TS varies widely with changes in temperature and humidity, and also with the change of air pressure.I know a German site that tested 2 of the an10 qts around .411 while the website lists qts = .278
8ft3 tuned to 30hz.
Norman
The TS are very usefull to evaluate the driver, but mesearuments after the ready box are boring and redundant, if I had ears to listen...I don't get too hung up about Thiel Small parameters, I'd rather let the ear be the judge. Still recognise measurements are important, but mainly for reference and understanding
I have found they also change with signal output. So what is the correct output? Should they be tested at 1 Watt and 10 Watts or more apropriately what gives you 90 dB and 100 dB and then take an average? Should they be tested in free air or on a baffle? If on baffle then what size shoud the baffle be?
I will be building an Onken for the 10s to see how they sound
Just having a conversation with Jeff. A different cabinet design will be needed for the neo driver which is quite different from the ferrite 10 the An-Ken was designed for.
dave
- Full Range
- My New Audio Nirvana Drivers
