My new 1.5kW SMPS Some reviews
Hi
I have developed a 1.5KW smps for class AB amps . It is still under testing will publish results .
Topology used :- Full bridge .
Output :- +-95V @ 15A
Input Voltage :- 230VAC @ 50Hz
Features :-
1. Input Over Voltage Protection
2. Short Circuit Protection
3. Over Temperature Protection
Some Pics Attached :-
Phoenix 87
there is an error on the schematic. one of the negative rectifiers in the output is connected reversed.
you need to add PFC to make this work properly. a resonant design has less stress on the igbt's as the leakage inductance of this design will give you quite some ringing.
sorry , I don´t have one.
a good starting point is the nxp resonant controller/pfc combo IC.
the nxp design tool is very instructive and gives transformer design details.
it iss limited to approx 350W, intended fro tv sets etc.
from there you can redesign the stages to accomodate the higher power.
even if you have a schematic, good physical design/layout is key.
good luck.
