Today's PC base source become more and more extensive range of applications
In order to allow the PC base compared to analog equipment with the same musical
A well-designed linear power has become the indispensable PC base's hardware equipment
This linear power supply chassis outer dimensions (including panels, floor mats, non-switch)
310mm deep x120mm wide x130mm high, net weight near 8 kg
The machine use 8mm-10mm aluminum alloy to achieve good electromagnetic shielding and shock control
No cooling fan and no shake to the chassis
At the same time a very solid chassis structure let the linear power of the number of units
Could be stacked on top of each other use
And will not detract from the performance of the sound
This linear power use 150VA (150W) of power transformer
Maximum available DC output of 120W or 10A
Such as the +12 V/10A, +19 V/6A, +5 V/10A single DC power supply output
Or +12 V/5A plus the +5 V/5A total 10A Dual DC power supply output
A well-regulated power supply must be in large, small current output keep stable
To make the power supply in the high-current output is still able to work in very stable conditions
We need large output capacitor and the decoupling capacitors
Large-capacity capacitor could extend the life of the capacitor
That is, let the linear power under a long period of use
Will not let the sound quality deterioration
Basically large-capacity capacitor will not slow down the speed of sound
Incorrect circuit design is the main cause to slowdowns
Wrong transmission circuit and power supply circuit
Will be slow down the speed of sound in the case of large-capacity capacitor,
This is why I used scaffolding
Self-scaffolding can set the best state of the circuit
Will able to maintain the feedback network stay in low phase shift
Even large current thus the load end
This will let PSU keep very low distortion
This PSU used XLR for DC output
So change different DC connectors
This PSU will fit all devices
Have a good power supply circuit then you need good cord to maxium performance
Good wire will lower electronic interference and diffraction phenomena
So as to have good sound quality
This PSU used my self-developed Teflon silver plated wire for top sound quility
Meanwhile, in order to ensure that the output performance of the linear power
Power transformers are no longer buy from the market
Instead of using my self-winding transformer to control quility
It has been confirmed through the measured
Mechanical vibration will gain electronic components's electrical harmonic shock
Thus resulting in the deterioration of the sound
Good power also need a solid chassis
One great PSU is actually a series of good details of the deal
With a good platform will reduce parts and circuit effect to the sound
The HighEnd audio depends on the know how in optimize to hardware & software
Not rely on parts or circuit
