jacco vermeulen said:
John,
you don't happen to have the DK number handy, before i toss myself over the balcony ?
I gave up on finding a chassis mount 30Vac (or twin 15Vac), so anything will do.
Whaaaa??
Low power (<20VA) 30V, 15V-0-15V or twin 15V secondary chassis mount (clamp or toroid) transformers are as common as muck over here!
Do you guys have Farnell over there? A few to choose from:
http://au.farnell.com/multicomp/mcfe015-15/transformer-15va-2-x-15v/dp/9531670?_requestid=806733
http://au.farnell.com/multicomp/mcfm50-15/transformer-mini-5va-2-x-15v/dp/9531530?_requestid=806541
http://au.farnell.com/multicomp/mcfm70-15/transformer-mini-7va-2-x-15v/dp/9531602?_requestid=806595
http://au.farnell.com/multicomp/mcfg015-15/transformer-15va-2-x-15v/dp/9532102?_requestid=806655
http://au.farnell.com/multicomp/mcf-b1815f/transformer-6va-2-x-15v/dp/1172356?_requestid=806206
http://au.farnell.com/dagnall-elect...mer-20va-2-x-15v/dp/1166183?_requestid=806417
http://au.farnell.com/dagnall-electronics/d3632/transformer-6va-2-x-15v/dp/1166330?_requestid=806481
Similar selection from RS Components too.......
Stuey said:That's a work of art, MJL.
Hi John
Just saw your K10A ... wow ... strewth mate, that's a bloody beauty 😎 🙂
Keep up the good work ...
Stuey said:
Thanks John. Quite innovative!
Thanks Stuey. 🙂
John,
Hi Jacco,
I used Digikey part MT2132-ND. This is a dual primary, dual secondary 28VAC, 12VA. It has pins for board mount, but I soldered leads and screwed it in place inside the "black box".
KLe said:
Hi John
Thanks KL,
Now all I need are the speakers to play this through...
Elektor78 said:compliments really beautiful ! 😀
Thank you Elektor,
Not sure what you mean C13/14 comment. Can you clarify?
Very cold here this morning. I can't recall it being this cold before. A good day to DIY! (inside 😀 )
Yes, that's -36*C. 😱
MJL21193 said:
Remember, mine is NOT the RMI, mine is an Abomination!
Sounds spectacular. The best amp I've built so far.
Thanks John for your impression. I'll surely build the RMI later. 😀
And who says global warming is coming? 😀
No symptoms of it here today! Burrrr!
Stuey said:Hmmm, it's been ~+36C here for a couple of weeks now!
Stuey said:John, where are you located (if you don't mind telling)?
If you look up, you will see John looking down.
It's true!MJL21193 said:
-40degC = -40degF.
What is the fluid used in a +50degC to -50degC thermometer?
Canada eh,
My fellow countrymen are embarrassed by my behavior sometimes so I've spared them the shame and took away my location. 😀
Nico Ras said:
If you look up, you will see John looking down.![]()
How's it going Nico? Having a good 2009 so far?
AndrewT said:It's true!
-40degC = -40degF.
Hi Andrew,
I'm not sure what fluid is used but the thermometer is broken now. This leads me to the conclusion that it may have been even COLDER than -36!
According to the weather forecast on my email page this morning it is only -27*C today.
Normal for here at this time of the year is a bit warmer.
I am running some tests with RMAA to evaluate (objectively) the performance of this amp.
Results soon...
Results soon...
As promised. The tests were run at about 3 watts of output power (into 8 ohms). Both channels were tested at the same time and the results are for both.
First the overall scores. Ignore the stereo crosstalk - the attenuator I use has a common ground so it invalidates that test.
Next the THD:
Frequency response:
Noise:
IMD:
Not too shabby, what? I'll take it. 🙂
Next the THD:
Frequency response:
Noise:
IMD:
Hi 😀MJL21193 said:
Thank you Elektor,
http://i412.photobucket.com/albums/pp206/MJL21193/Picture778.jpg
As the Pc Supply.
for the transport I find it very comfortable.
- My K10A build
