my first sub.
For the Frg in this equation. Is that the freq that you just start to get room gain or is that supposed to be like a +3db point or something? I know it's only an approximation but I just want to know if I should plan my sub's -3db point at Frg or should I try and stay fairly flat down to that point?
richie00boy said:
Frg = 344 / (longest dimension / 2)
assuming metres
The theory assumes a fairly well sealed room and is the transistion between waveform reproduction and room pressurisation. I've seen curves bandied about from 6dB/oct to 12dB/oct boost. I've also seen a generic model that the curve begins at around 100Hz and rises up to give 10dB gain @ 20Hz.
Note wrong formula above, should be longest dimension * 2
:att'n:
