My first ESL: works but VERY quiet
I_Forgot said:
I think you're getting ahead of yourself.
Graphite will not give a coating that is more than 50 Meg Ohms, especially if you "used too much". Graphite will typically read in the 100k-2 Megohm range. How did you do the measurement? How did you apply the graphite? Does the diaphragm look gray (it should). Are you sure you connected the right side of the diaphragm to the bias supply? Did you connect the other side of the bias supply to the center tap of the audio transformer(s)?
ESLs will play at very low volume with no bias supplied because the diaphragm will pick up charges just from being handled. The film may also retain some charge from the film manufacturing process.
I_F
I applied the graphite by sprinkling some on the diaphragm and rubbing it in relatively hard with cotton wool. I tried to get an even spread as I could. It looked grey and if I rubbed it it, I would get graphite deposited on my finger.
I attempted to measure the resistance by putting two copper pennies on various points of the diaphragm and putting the probes on them. I could not measure anything.
The bias supply is connected to the diaphragm via copper tape. I has a big surface area touching it
I've ordered some neon lamps (annoyingly in packs of 10) in order to build a leakage indicator!
Here is the schematic
My neons arrived today and I wired up the schematic for the leakage detector, but it acted strangely. Sometimes it blinked as the bias supply was turned off, blinked about once as I connected the diaphragm wire, and the neon GLOWED IF IT TOUCHED IT?
Is my bias supply just making high voltage AC or something? Or at least pulsed DC?
Ok, with a bit of fiddling I got the indicator working. With just a sharp wire coming from it, not connected to the diaphragm, it works sanely. As I bring my hand to the end of the wire, it flashes faster. Bring a grounded object nearby and it flickers quickly.
If I connect my diaphragm to it, it just says on 😡
My panel is obviously leaking massively. I think coating the stators with acrylic lacquer is the easiest way to solve this, am I right?
gvy said:
May be, while coating the membrane with the graphite, and not being carefull, you made a low resistive leakage path to the metal stators?
Geert
Perhaps.
I just got a spare stator panel on its own and connected it to the EHT lead and the neon flashed about 5 times per second. There is no way this can work with these panels uncoated. They seem to have too many sharp edges to leak from.
Welcome....
to the world of insulated wire stators where there are no sharp edges. There are of course ways around the troubles that you are experiencing because perf metal stators are made that work just perfectly. That said I believe that while wire stators are more fuss to make than are perf metal stators the end results are far more dependable/reliable (for the DIYer) than the kinds results that you are going through.
Buy the right wire wind your stators and glue the wire down. Done like dinner, they will work and keep working for a very long time. Do it right and you only have to do it once.
As an aside there are sources out ther where you can purchase professionally made insulated perf metal stators that look just like those that people like Martin Logan use. So if that is what you are after the money to buy them is well spent. The devil lives in the details and if they have sharp edges there is no amount of insulation of any kind that you can apply to fix that little detail. You will be better served to start over and deal with the issues at hand or find anothe method that simply circumvents those issues.
Well, a typical small tube output tranny with turns ratio on the high side will be able to match 8k to 4R. Impedance ratio of 2000, so turns ratio of 44. Not a big difference and it's tough to find higher impedance trannies than that.
40:1 isn't huge for an ESL (50 or 60:1 would be better), but it's not that far out of range. Figure that 30V out from a medium power amp will drive 1200V to the stators. Translating to peak, that's about 1700V.
Hi Bigwill
just a couple of thoughts and apologies if they've already been discussed...
the last time I asked(admittedly about 3 years ago) I was quoted £10-£15 for 4 x 4'x8" panels to be powder coated in Hull....ergo its not expensive if you can find a place...
also
Its usual for perf sheet to be sharp only on one side..is it not possible to orient the stators in the best direction to minimise this leaking???
also that polyeurethane glue that Rob Mackinley uses is very efficient as an insulator...
also IMO the ratio is low but I'd sort the leakage problem before upping the volts ...you might inadvertantly become a wicked firestarter....lol
Ed
Unfortunately the edges of the sheets have a small lip, as they are baking trays. They have to be back to back, and unfortunately that is the side where the perforations are sharp 🙁
Ok, with some experimentation I was actually able to get the flash rate on my ESL panels (not just the bare stators, a built panel) down to about once every 1-2 seconds. Apparently it was leaking through the table it was leaning on. I insulated every surface making contact with anything with bluetac. Despite this, the ESL still plays really quietly (albeit slightly louder)! :bawling:
I don't know what's going on!
I have a valve output transformer that I'll try driving the panels with tommorow.
bigwill said:
Hmm, I do have some ferric chloride granules and a large plastic box that could be used as a bath....
I'm a bit wary of this though
Start with a very dilute solution. Aluminum reacts much faster than copper and if you use it at "copper" strength you'll have a nasty, boiling mess on your hands. The sharp corners on the holes will be the places where the metal dissolves first so you won't need to leave it in there long.
I_F
